Post by ODJeepster on Jan 10, 2016 8:53:30 GMT -8
Frame reinforcement looks awesome!!! Are you contacting your bumpstop? Is your trackbar contacting the frame? If all dit will take to fit 39.5's is changing location of upper airspring mount, then no biggie. If you will have to re-engineer your link placement and/or link lengths maybe now would be a better time to tackle it since mounts are easily moved at this point. Then again, you still have a couple seasons of use left on those BFG's
Post by petee on Jan 10, 2016 17:24:37 GMT -8
Ya thats on the bump stop and the opposite is as far down as it will go. Nothing is hitting or making contact with hard parts. I have not solidified the upper air shock mount yet so I could factor that in and make it stop sooner. But I would need to commit and get the size I'm going to run.So I can mock it up
Post by petee on Jan 10, 2016 20:04:10 GMT -8
Link placement is not currently interfering as far as I can tell. I really want these. Anyone have a set they want to trade.
Post by ljdude on Jan 10, 2016 21:19:47 GMT -8
So that's what flex under the CJ looks like.
Post by ODJeepster on Jan 10, 2016 21:43:39 GMT -8
Holy cow!!!! Those tires are worth more than my Jeepster.
Post by petee on Jan 11, 2016 5:07:18 GMT -8
So that's what flex under the CJ looks like. Hahaha. It's not the pants that make you look fat.
Post by petee on Jan 11, 2016 5:08:34 GMT -8
Holy cow!!!! Those tires are worth more than my Jeepster. I know, it's insane. I assure you it won't happen but I can want can't I.
Post by petee on Mar 5, 2016 19:56:59 GMT -8
Post by ODJeepster on Mar 5, 2016 20:14:23 GMT -8
Quality workmanship and design, nicely done Paul
Post by petee on Mar 7, 2016 20:18:52 GMT -8
So as you can see I have been working on the jeep some. I picked up some parts at the swap me in excited about. And these followed me home. And I might have thrown the rears on to take a look.
Post by bigstuck on Mar 8, 2016 17:31:38 GMT -8
Looks good but you need a bigger garage.
Post by ljdude on Mar 8, 2016 21:49:54 GMT -8
Looks good but you need a bigger garage. We just need to jack the garage up and add one more layer of cinder blocks. Good to go!
Post by petee on Mar 14, 2016 19:46:53 GMT -8
Post by petee on Mar 14, 2016 19:51:42 GMT -8
Next is shock hoops and steering. I have new steering shaft u joints coming in. Then I can made the steering shaft. Also the hydro assist stuff should be here this week then I can run the lines and mount the ram. I will send the shafts off to be resplined. I bought a really long chromo a few years ago and cut it down. Then cut down the stock ford long side shaft to the narrowed length. Then picked up a "cut to fit" chromo at the swap meet and cut it the other night too.
Post by ExCabSwap on Mar 15, 2016 1:24:05 GMT -8
Holy crap that's awesome! What is that, like a 10 degree approach angle?! lol, time to climb over some barriers!
