MtbDog
Post by MtbDog on Mar 24, 2013 20:00:16 GMT -8
1999 TJ Wrangler Engine 4.0 Transmission Auto Transfer Case 231A HD with a Teralow 4:1 using the short shaft kit Front Axle Dana 30 w/ARB Locker Warn full floating kit30-spline with a 5x5.5 bolt pattern Gear ratio 4:11 Rear Axle Dana 44 w/ARB Locker 30 spline Dutchman Axles 5X5.5 bolt pattern Teraflex rear disc brake kit Gear Ratio 4.11 Suspension Teraflex 4" Long Arm Kit, Currie Enterprises tierod Teraflex quick disconnect swaybar links Doestch Tech Shocks Tires 35x13.50-15 Toyo MTWheels ARE Recovery Engine compressor on board air Warn xd9000iOn Board Air and Warn 9.0i winch Armor Rocker Guards Sliders are converted into air tanks Currie Enterprises Rock Crawler 2 Rear Bumper with spare tire carrier Front Bumper is a custom made piece and has a Stow Master tow bar system. Accessories Hella Lighting,Alpine CDA-7998Infinity speakers in dashSony Speakers in sound barCobra CB Clifford Intelliguard SecurityTuffy Lockable Glove Box Attachments:
Post by ljdude on Mar 24, 2013 20:43:21 GMT -8
Nice build! See you out on the trail!
Post by iceman on Mar 25, 2013 18:55:41 GMT -8
Very nice rig! Hope to get out on the trail soon with you.
