Post by ODJeepster on Sept 3, 2014 18:39:32 GMT -8
Hey everyone, I am starting this as a build thread for my 1969 Jeepster Commando that I bought from Woody's 4x4 earlier this year, bone stock runner driver. This one has the better stocker parts than some like Saginaw power steering, multi spring rear leafs and the dauntless 225ci Buick V-6.
Post by ODJeepster on Sept 3, 2014 19:09:11 GMT -8
Started off lifting the body 1-1/2" using aluminum spacers. Then I began searching for lift kits. I did not want to spring-over yet....if ever because the amount of body roll. So I decided to do my own custom spring packs. With the advice and help from Gary and Lee at Woody's 4x4 I bought some used early CJ lift springs, cold arched the stock Jeepster spring to match the arch of the CJ's. Jeepster springs have an offset center pin both front and rear so I cut and the CJ springs to sit in the pack where I determined best. I came up with 7 leafs in the front spring pack. The thinner leafs are the CJ leafs.
Post by ODJeepster on Sept 3, 2014 19:26:08 GMT -8
Built the rear springs the same, 7 leafs combining both style leafs. The front shackles are very similar to XJ rear and Waggy front, so I purchased JKS 1" lift Cherokee boomerang shackles. Had to narrow the bushings by 3/16" each to fit in the frame bracket. Also fabbed some u-bolt skid plates.
Post by ODJeepster on Sept 3, 2014 20:28:21 GMT -8
Post by petee on Sept 4, 2014 7:13:16 GMT -8
Nice jeepster. I love the bastard packs. How's my old Ranger running these days?
Post by bigstuck on Sept 4, 2014 9:29:17 GMT -8
Hey Shawn welcome to the group. Cool Jeepster build you got going there. I've always liked those rigs. They are on the list of wants for sure.
Tom
Post by ODJeepster on Sept 4, 2014 21:08:37 GMT -8
Nice jeepster. I love the bastard packs. How's my old Ranger running these days? Ranger is still running great, just put some new tires on today
Post by ODJeepster on Sept 23, 2014 12:18:58 GMT -8
Well I scored a Warn M12000 winch the other day and have begun fabricating a winch mount and bumper. Starting point for bumper 6"x4" .120 tube
Post by ODJeepster on Sept 29, 2014 16:24:17 GMT -8
I began cutting along my layout lines. Tubing likes to change dimensions when you cut a side off. I decided to add stiffeners to maintain the correct width.
Post by ODJeepster on Sept 29, 2014 16:26:30 GMT -8
Fit the center top section and tacked
Post by ODJeepster on Sept 29, 2014 16:28:19 GMT -8
Notched for steering box clearance
