Post by ODJeepster on Sept 29, 2014 16:31:13 GMT -8
Finished welding and grinding smooth. Still have more to add, like my shackle mounts and I've decided to taper the ends a little before I cap them off.
Post by ODJeepster on Sept 29, 2014 16:36:59 GMT -8
Fabbed this during my last 4 lunch breaks, it's a little heavy being 1/2" steel, but hey it was free!!! I will be drilling some 2" holes to lighten it up a little bit.
Post by 4stgmby on Oct 2, 2014 9:24:12 GMT -8
Shawn, looks Great! you have been busy. good job
Post by ODJeepster on Oct 2, 2014 18:37:56 GMT -8
Shawn, looks Great! you have been busy. good job Thanx Greg, honestly I gotta stay building if I wanna keep up with you on the trails!!!
Post by ExCabSwap on Oct 3, 2014 22:36:31 GMT -8
Fabbed this during my last 4 lunch breaks, it's a little heavy being 1/2" steel, but hey it was free!!! I will be drilling some 2" holes to lighten it up a little bit. That's AWESOME! I wanted to design one, but what size steel should I use? I was thinking 1/8" but i don't want it too flimsy...
Post by ODJeepster on Oct 4, 2014 9:42:23 GMT -8
Thanx for the compliment...1/8" steel is a little light if you plan on using your winch. 1/4" steel is fine with some gussets or a flange. I used 1/2" because it was free to me.
Post by ExCabSwap on Oct 4, 2014 11:40:44 GMT -8
Yeah, you're probably right... My original plan was to use 3/8" AR500, but then my front bumper would be REALLY heavy... Maybe I'll use 1/4" AR500!
Post by ODJeepster on Oct 4, 2014 21:09:55 GMT -8
Painted and installed and then I tried to set the winch in.....OOPS!!! one dimension overlooked...dang it. I didn't leave myself enough room between the winch mount and the grill and now I have to modify and move the mount 3/4" away from the grill and over the top of the bumper. I should have test fit the 136lbs winch earlier...oh well, lesson learned lol
Post by ODJeepster on Oct 4, 2014 21:37:11 GMT -8
Post by ljdude on Oct 5, 2014 19:59:29 GMT -8
purdy
Post by ODJeepster on Oct 13, 2014 8:06:41 GMT -8
Got the winch mounted and wired after modifying the mount plate
Post by ODJeepster on Oct 13, 2014 8:10:16 GMT -8
Got my twin stick in the mail from JB Fab
Post by 4stgmby on Oct 13, 2014 10:17:54 GMT -8
SEXY!
Post by ODJeepster on Oct 13, 2014 13:07:44 GMT -8
Removed the original shifter assembly which leaves this shaft
