Post by ljdude on Dec 2, 2014 19:44:53 GMT -8
I like the fancy bolt. Why did you have to replace it? lol
Post by ExCabSwap on Dec 2, 2014 20:20:34 GMT -8
If you look closely, you can see the hourglass shape in the bolt on the the left... it's a grade 5 bolt, but instead of snapping, it just stretched a bit... didn't want that guy snapping on me..
Post by ExCabSwap on Dec 9, 2014 23:09:42 GMT -8
Post by ExCabSwap on Dec 9, 2014 23:12:15 GMT -8
That's the oil fill/return and engine mounting plate. The mounting plate is because I was too cheap to pay the $40 people wanted for the factory A/C mount.
Post by ExCabSwap on Dec 14, 2014 13:37:56 GMT -8
Made some progress!
I pulled an A/C idle up VSV from a 3.0 It has an adjustment screw so that I can manually set the idle up speed.
Green lines mark the vacuum headed to the VSV, and then to the larger diaphragm. When power goes to the VSV, it opens, and vacuum is applied to the diaphragm. When vacuum is applied to the diaphragm, it opens up the larger bypass, allowing air from the blue line through, and into the intake through the red line. Next is to tap into the TPS, and wire up a normally open relay, so that the EGR is 'tricked' and simulates that the throttle is open. Then, wire both the relay, and the VSV to a time delay relay, and into the switch in the dash.
Hard work is starting to pay off
Post by ExCabSwap on Dec 16, 2014 19:26:35 GMT -8
Finally got the power to the Control Panel wired up!
Post by ExCabSwap on Dec 19, 2014 0:37:24 GMT -8
Here's the live test of the Idle up!
Enjoy!
Post by petee on Jan 23, 2015 13:51:31 GMT -8
I would think most any "engine bay" hose is going to survive. I opened the hole on the filter itself and slid it right over the barbed fitting then added hose clamp. No hose inbetween. But the space you have might not allow that, I don't know?
Post by ExCabSwap on Jan 24, 2015 3:04:45 GMT -8
I would think most any "engine bay" hose is going to survive. I opened the hole on the filter itself and slid it right over the barbed fitting then added hose clamp. No hose inbetween. But the space you have might not allow that, I don't know? Thanks for the suggestion!
Post by ljdude on Jan 25, 2015 19:26:35 GMT -8
Couldnt you just use a shorter belt?
Post by ExCabSwap on Jan 25, 2015 19:49:54 GMT -8
Tried that. As it is, the belt barely pulls over the pulleys. Once it settles into the groves, it's got too much slack to take up, so I'm repositioning the York about an inch higher
