Post by hootie on Sept 3, 2009 15:38:21 GMT -8
U BOLTS made to your specs.
Thread dia. from 3/8 up to 1-1/4 inch.
Information required to manufacture:
Thread diameter Inside width Inside length Type of bend (round, square, or semi-round)
If you're not comfortable with taking your own measurements bring a sample and we are more than happy to do that for you.
Benz Spring Company 4330 S.W. Macadam Ave Portland, OR 97239 503-224-4865
Business hours: M-F 7:30-5:00
Post by racincowboy on Sept 3, 2009 20:51:58 GMT -8
Oregon Spring will make them custom for you as well.
Same specs needed or a sample even if it is not long enough. They will need to know what size block you are using to lift for correct length.
They are in Portland as well. Around 5th and Belmont around that area. Call for directions.
503-234-9611 or Toll Free 800-423-6976
Post by fry on Nov 18, 2009 8:52:59 GMT -8
oregon spring is on tenth and stark. one of my long time friends worked there as head mechanic for over ten years. i have had them do a couple sets of springs for me over the years.
the last set of springs i had custome made was done by benz. i was completely satisfied. i have have many springs built by benz and it is my opinion they offer the best value.
Post by fivendime on Nov 18, 2009 11:50:38 GMT -8
Benz springs did the custom set on my willys pickup and I was happy, they even put the original style bronze bushings in for me. Springs are way to stiff but that's my fault, had them built as 1 ton springs like the factory ones were.
redxj
Post by redxj on Nov 18, 2009 13:31:33 GMT -8
They are in Portland as well. Around 5th and Belmont around that area. Call for directions. 503-234-9611 actually 10th and stark. thanks fry
Post by hootie on Nov 18, 2009 18:34:02 GMT -8
got my U bolts at Oregon Auto Spring on 10th and Stark. Today.
2 Ubolts with nuts and washers $20. and 4 minutes flat.
Post by racincowboy on Nov 19, 2009 11:08:54 GMT -8
See what I get for trying to go off of memory where Oregon Spring was.
I have dealt with Oregon Spring and Benz Spring both for multiple things and I am happy with both. It usually ends up being a time crunch on my part and who can get to it sooner.
Post by fry on Nov 19, 2009 11:41:28 GMT -8
there used to be another outfit off 10th or 11th and columbia called Betts Spring. they did the springs on my very first lifting of a corn binder back in the late 80's. i dont even know if they are still around.
