Post by mudmaddness1972 on Dec 5, 2009 11:45:06 GMT -8
Post by mudmaddness1972 on Dec 5, 2009 11:45:42 GMT -8
Post by mudmaddness1972 on Dec 5, 2009 11:48:11 GMT -8
it has a 8in skyjacker lift and will have detoit locker in the rear and a 427 big block chevy w/400hp and a th400 for now a np203 w/part time kit..it will have a dana 60 in the front (in a year or two..)and have a set of 38.5 or 40in and a hide away winch behind the front bumper.
Post by hootie on Dec 5, 2009 12:53:10 GMT -8
Nice looking burb. will be a good one for Sand Lake and Snow Runs...
Post by windturbine1 on Dec 5, 2009 19:46:12 GMT -8
sweet ride. what mods did you have with steering and drivelines with the 8in lift?you are a little more ahead on yours than i am on mine so if you dont mind i would like to pick your brain a little.
Post by mudmaddness1972 on Dec 6, 2009 9:14:47 GMT -8
i might do the cross over using the ord nuckle and for drive lines 8in is the lemit with the stock lines.
Post by windturbine1 on Dec 6, 2009 12:37:28 GMT -8
ive thought about that same crossover kit as well. stock drivelines will take an 8in lift? i had a buddy that had an 87 he installed a 6in lift and his were too short. every vehicl is different i guess. ill just have to lift mine and find out how much mine will take. maybe with your being an older model you have different drivelines. or maybe his were replaced at one point with something different.
Post by mudmaddness1972 on Dec 8, 2009 20:41:42 GMT -8
ive thought about that same crossover kit as well. stock drivelines will take an 8in lift? i had a buddy that had an 87 he installed a 6in lift and his were too short. every vehicl is different i guess. ill just have to lift mine and find out how much mine will take. maybe with your being an older model you have different drivelines. or maybe his were replaced at one point with something different. they are too short with the slip yoke in the rear ...man been to cold to work on the burb..been planning on how to mount the winch...and getting ready for christmas too...
Post by windturbine1 on Dec 8, 2009 21:17:34 GMT -8
i hear ya about the cold. thats why mine aint runnin yet. so if the rear has the slip yoke at the transfer case then its too short but if it has the u-joint slip yoke its fine?
Post by mudmaddness1972 on Dec 9, 2009 16:58:40 GMT -8
i hear ya about the cold. thats why mine aint runnin yet. so if the rear has the slip yoke at the transfer case then its too short but if it has the u-joint slip yoke its fine? i found that on slip yoke are shorter then the fix yoke (drive shafts)
