Post by lowboy55 on May 12, 2010 19:15:29 GMT -8
I have a 2004 Toyota Tacoma Double Cab
My list of wants Bumper (just bought ARB) Winch (just bought Warn M8000) Need to buy Lift, 3" (no spacers) Single deep cycle battery 140amp ALT On Board Air Lights, spot, flood, fog
Want to build 2x4 Sliders with steps Rear bumper with tire carrier
What sugestions do you have for me
Post by oltmann on May 14, 2010 10:01:37 GMT -8
Viair seems to have good options for electric onboard air compressors.
You could also run a CO2 tank with fittings to a system that is permanently plumbed for an external quick connect, and to any other air 'accessories' you might want to use.
Post by toyrocs on May 14, 2010 11:17:44 GMT -8
Lowboy55: If you plan on keeping your truck & need good reliable air , use an engine driven 210 York compressor. This will quickly fill/ re-seat tires, run air tools all day long-- all your buddies will be asking for you to fill THEIR tires at the end of the day! Below is a company that makes a bracket kit for the 210 York compressor to fit 3.4l Tacomas. There are some things in the engine bay that need to be relocated to make it all fit, but it has & can be done. www.pnwfab.com/YorkOBAmount.htm A 210 York compressor can be sourced from Pick & Pull parts for less than $20. Rebuilt for around $150 . With all the extra parts to complete the installation: tanks, valves, fittings, pressure regulators/ filter, hoses, belts, the price does add up Quick, but you will never have to buy another OBA system! Hope this helps. Toyrocs
Post by czjeeper on May 14, 2010 11:26:11 GMT -8
I love my York. I had 12V, and it was too slow... CO2 is great, but you have to certify the tanks and it costs to fill them. EDC OBA is free once it's in!
Post by Wyldman on May 14, 2010 13:40:41 GMT -8
Has far as lights. I've been very pleased with my "KC slimline" day lighters. They have both driving and flood lights.
Post by oltmann on May 17, 2010 8:23:16 GMT -8
I didn't know there was a York option for the Taco's. That is the best OBA solution hands down!
Post by toyrocs on May 18, 2010 9:21:06 GMT -8
I have a 2004 Toyota Tacoma Double Cab Need to buy Lift, 3" (no spacers) Single deep cycle battery 140amp ALT On Board Air Lights, spot, flood, fog What do you need a 140 amp alternator for ? The stock one will do just fine. Even with occasional winch use-- just let the winch cool down while at the same time your OEM alternator charges the battery. Try using your stock battery first as it may have more than enough reserve capacity for your use. You can always upgrade the alternator/ battery later if you find you need it ---- but I bet you don't! Save your money for more fun stuff like your sliders/ lift/ on board air. Don't waste your money on too many lights, as you will find you don't need/ use them! Besides many extra lights that are installed on trucks, get damaged/ torn-off by rocks ( rock lights), tree limbs, tree trunks etc. If do install them, have a good protected area to mount them. Toyrocs
Post by lowboy55 on May 26, 2010 12:47:31 GMT -8
ARB Bumper and Warn M8000 are here, now i just need to find time to mount them
Post by lowboy55 on Jun 6, 2010 18:53:07 GMT -8
Bumper and winch are now on, now it gets a 3" lift and Black Steel wheels
Post by lowboy55 on Jun 6, 2010 19:25:04 GMT -8
This time with a picture Attachments:
Deleted
Deleted Member
Post by Deleted on Jun 10, 2010 19:57:00 GMT -8
Ordered new black steel wheels from Les Schwab, they had it half a day (I was at work so no big deal) and called to say that the offset was wrong and they had to put my stock rims back on.
Bummed me out, now I have to go find other wheels
Any suggestions
Deleted
Deleted Member
Post by Deleted on Jun 11, 2010 6:59:17 GMT -8
This is just not my week. Yesterday the new wheels did not fit, today the mechanic who does the lift did not show up for work. Now I have to re-schedule. Why is it so hard to spend money???
Post by fivendime on Jun 11, 2010 7:21:49 GMT -8
This is just not my week. Yesterday the new wheels did not fit, today the mechanic who does the lift did not show up for work. Now I have to re-schedule. Why is it so hard to spend money??? You are having a bad week. hopefully you get a better deal from these problems IE a cheaper price for dealing with un-professionalism
