Post by xtrmtj on Jul 1, 2010 14:00:49 GMT -8
Back ground: I run a HP D44 and full hydro steering. The axle came without steering stops. I have replaced the u joints several times due to over steering/too great of an angle on the knuckles. My question: What is the max operating angle for a Spicer 5-760X ? Before you start damaging it ? Also, how do you measure such an angle without some fancy tool to do so ? TIA !
Post by fivendime on Jul 1, 2010 18:43:55 GMT -8
I would try this. Put the front end of the Jeep off the ground and put it in gear to turn the front wheels. Have someone turn your steering wheel slowly. I think the U-Joint should start making a popping noise and have a noticeable movement when they get to the critical point of too far. Other then that I have no idea on the turning radius.
Post by tonka on Jul 6, 2010 5:26:18 GMT -8
Joey, is right you should get a bind when its to far some times I will limit turning to save ware on the Joints! The angle can be measured with a cheep angle finder
