Post by TORX on Jul 2, 2010 11:10:20 GMT -8
I didn't know the four squirrels made enough power to break an axle. ;D
What did you have in there before, and where did you break it?
I think the new RCV's will do the job.
Post by anglebar on Jul 2, 2010 13:26:03 GMT -8
I didn't know the four squirrels made enough power to break an axle. ;D What did you have in there before, and where did you break it? I think the new RCV's will do the job. Stock axles are great for pound the gravel roads out here or cruising the mall, but not doing wide open throttle assaults on Waterfall ;D
Post by The Black Jeep on Jul 2, 2010 16:41:04 GMT -8
Those look nice. I up-graded the Black Jeep Cherokee Rescue Rig Dana 30 axles to CV axles from u-joints. Was hard finding the right ones where the axle seal wouldn't leak. The newer grand cherokees come with CV axles on the Dana 30. They bolted right in without any mods. Probably not as strong as those that you got, but I figured it is an improvement from the u-joints.
Post by fivendime on Jul 4, 2010 6:54:34 GMT -8
Those are exactly what I would put back in as soon as mine decide they hate life on the trail. Looks good!
Post by tonka on Jul 6, 2010 5:20:56 GMT -8
Only time and a v8 will tell the truth hope they hold up
Post by xtrmtj on Jul 6, 2010 7:54:14 GMT -8
Did that give you more or less turning angle/radius ? Looks sweet !
Post by xtrmtj on Jul 6, 2010 7:58:15 GMT -8
Can you give me the 411 on these ? How much stronger are they ? Who makes them ? Details man, Details ! ;D
Post by fry on Jul 6, 2010 8:33:12 GMT -8
Can you give me the 411 on these ? How much stronger are they ? Who makes them ? Details man, Details ! ;D yes they are awesome and fAnCy ;D. they look like Bobby Longfields junk, he did up some of the fancy stuff for jeeps a year or so ago. as i remember his junk was over my budget for inners/outers by a long field at almost a grand. www.longfieldsuperaxles.com/
Post by fry on Jul 6, 2010 8:36:51 GMT -8
they are strong enough to not break. they make everything els the weak link, axel tubes, ring and pinion, driveline u joint, ect. you wont ever have to carry spare axels again.
Post by anglebar on Jul 6, 2010 15:34:12 GMT -8
Post by anglebar on Jul 6, 2010 15:40:23 GMT -8
Here is a custom RCV shaft that came out of Tim Cameron's "Moon Rover" It has 14 bolt axles at each end with rear steer, and a lot of HP And here is how he broke it
Post by TORX on Jul 6, 2010 22:17:48 GMT -8
Here is a custom RCV shaft that came out of Tim Cameron's "Moon Rover" It has 14 bolt axles at each end with rear steer, and a lot of HP Did you see the set of Boggers he was running on that? I find it extremely impressive that shaft held up as good as it did considering the driving style, HP from the BB, and the tires he was running. I think once Pat gets his V8 put in, he'll be the Tim Cameron of the PNW. ;D
Post by tonka on Jul 16, 2010 5:30:51 GMT -8
ha ha thats funny guys I think they will hold up the turning is tighter I can turn till the caliper hits the coilover now a lot tighter than a u joint I can get dealer pricing on these axles but there still not cheep. I also had to upgrade the hubs to 30 spline I hope the hub breaks first. if not the ring and pinion will be the weak spot
Post by bchutchens on Jul 16, 2010 19:42:32 GMT -8
Maybe I should have put those in... Looks awesome!
