patmac
Post by patmac on Jan 23, 2011 14:57:45 GMT -8
i am changing my gears in a 96 cherokee from 3.55 to 4.10 . i am keeping the d-30 and going to a 8.8 i was wondering if i had to change carriers . and also any info on setting up the gears would be great. thanks Attachments:
Post by bigstuck on Jan 23, 2011 20:41:22 GMT -8
Yes you will have to change carriers in the D30 as the split is 3.55 and down and 3.73 and up. The rear 8.8 there is no carrier change. If you have never done gears before take your time and have someone there that has as if you mess it up it will get spendy QUICK!! Randys ring and pinion wrote a pretty decent book on this subject if you got time to read.
Post by iceman on Jan 23, 2011 21:31:46 GMT -8
Bigstuck is correct. My only input is be picky. You only want to do this once. It dosn't take much to take it back out and change it, but once it's in the final time its done and if you have to take it back out you will be buying more parts. I would change all the seals and the bearings while your doing it just because its cheap insurance. Good luck man and take some photos of it and post up so we can see what you did so other people and reference it. Fivendime just did his on there XJ and put it in his build thread hear you might want to look it over. pistonswildforum.proboards.com/index.cgi?board=amcjeep&action=display&thread=829&page=3
Post by fivendime on Jan 23, 2011 22:05:58 GMT -8
Hey there, Like Iceman said I just finished doing my gears about 7 months ago. No issues and no problems because like he said, I took my time and did it right. Thats the biggest piece of info I can give is be patient and get them perfect. I had my D30 in and out at least 40 times and just when I thought I had it dead set I had to pull the pinion out and bearing off to re-shim it again. If you set a D30 up right it can be equally as strong as a d44 but only if its dead on perfect pattern. If you need any help or info let me know. Feel free to post up pattern pictures and I will be glad to give you a little help on what to do about getting the best pattern. The other bit of info is to have the best tools to do the job that you can. You will find that you need some very specific tools to do the job correctly. Hope I helped a little, and I hope to be of help in the future if ya need P.S. buy a good set of gears NO cheap ones, trust me on this one haha.
patmac
Post by patmac on Jan 24, 2011 18:51:23 GMT -8
thanks for all the info you guys are great .some day i will make to a club run i have been to two or three meetings .i did go buy yukon gears and a complete master overhall kit for the front and rear including inner axle seals.i will post pics thanks again for the info
Post by fivendime on Jan 26, 2011 19:54:00 GMT -8
thanks for all the info you guys are great .some day i will make to a club run i have been to two or three meetings .i did go buy yukon gears and a complete master overhall kit for the front and rear including inner axle seals.i will post pics thanks again for the info No problem, anything to help out! Come join us on a run!
patmac
Post by patmac on Jan 31, 2011 16:21:51 GMT -8
sorry no updates was ready to install gears and got a steel on some 4.56 for the front so now i gotta get gears for the 8.8...i have started to truss the dana 30 .got some gears for sale as well .i got 4.10s for a dana 30h/p r/r and dana 35 and 8.8 also have 3.73 for the 8.8 if anyone is interested hit me up 360 624 0628 asking 75 per set name is pat Attachments:
