Post by xjramrod on Mar 21, 2011 9:51:38 GMT -8
ok so i just got my 44/9in and they came with wheels all set up ready to go but they are about 3 inches wider than the 77in width i am now am i gonna be hurting at 80in any more than 77in or should i get so larger offset wheels
Post by bigstuck on Mar 21, 2011 17:47:30 GMT -8
Buy deeper offset wheels and get them tires under the rig. 80" is going to be a bit wide if I remember right there is at least one trail at tsf that is at 76" Already.
Post by xjramrod on Mar 21, 2011 18:05:19 GMT -8
not what i wanted to hear but thats ok now i got a second question is there any deffinent way to tell weather my radius arm mounts are cast or welded
Post by xjramrod on Mar 21, 2011 18:10:22 GMT -8
so you cant run any wider than jeep axles with 1 inch spacers cuz im at 77 already
Post by windturbine1 on Apr 23, 2011 23:33:25 GMT -8
i belive that bigstuck is correct on that trail. i do run a fullsize at tsf and have run a few trails and havent had any width problems. im sure as i run more trails i might come across a width problem here or there. but i think you would be fine at 80inches.
