Post by joshwho on Nov 5, 2011 22:37:33 GMT -8
I have a 8 lug Chevy (passenger side drop) big hub/ big knuckle dana 44 that has a carrier for 4.10 and deeper gears (it currently has 4.56's, but the previous owner that installed the gears set the depth incorrectly and ruined the ring and pinion), it does not have any broken joints or shafts. It has an older set of locking hubs that are kinda marred up, but still function properly. It has a pair of stock 16.5" steel wheels on it with some junky tires on them (on holds air, but the other doesn't) I'm open to trades for or towards a dana 60 35 spline locker or limited slip (for 4.56's), a dana 300 transfer case, 14" travel or larger remote reservoir shocks, I'm going to try the toyota thing, so toyota dual transfer case adapter, 4.7 toyota case gears, 23 spline input, 30 spline output, toyota crossover steering, Toyoya IFS steering box, stock 2 1/2 ton rockwell wheels, stock H1 Hummer beadlocks, a laptop with wireless ablity, a four gallon or smaller air tank. Cash may need to be exchanged on some trades.
