Post by joshwho on Nov 6, 2011 13:57:20 GMT -8
I have two steering Rockwell axles that have ZERO miles on them since a through rebuild. They both got brand new Timken bearings,, Detroit lockers, boots, hardware, shoes, wheel cylinders and whatever else would be a wear item. They got painted in thick red oxide paint and have since sat tarped with any hole filled with a plastic plug. I understand that most people that would buy these for an offroad wheelin rig would go to disc brakes, but with all the fresh parts you could easily recoup some cash selling the drum stuff to the deuce and a half guys. I'm looking to get $3000 for the pair or $1800 each. I am open to some trades, but I will probably need some cash depending on what you have and how many axles you want. Will trade for a first gen toyota 4x4, FJ40 with hard top, cj2a with a top, dana 300 transfer case, klune-v or black box range box, atlas transfer case, toyota to dana 300 adapter, np231 to dana 300 adapter, 14" travel or larger remote reservoir shocks, toyota dual transfer case adapter, 4.7 toyota case gears, 23 spline input, 30 spline output, toyota crossover steering, Toyoya IFS steering box, longfield axles, dana 60 35 spline or 40 spline locker (Ox locker or McNamara prefered), alloy dana 60 axles, 300m dana 60 u-joints, 203-205 doubler parts (I have both cases, but could go for 32 spline outputs and the doubler adapter), 39.5's or bigger, other crawler parts or a 1.9l TDI vw swap... what do you have? Thanks for looking, Josh
