Post by ljdude on May 2, 2013 19:30:42 GMT -8
Sucks about the tire! But other then that looks like you had a good time!
mudmaniac33
My names Lance and I party
Post by mudmaniac33 on May 2, 2013 20:26:46 GMT -8
yeah lame but i picked up one from a buddy thats like 75% and mine are like 35% so i may want to buy some new ones but trying to wait until tax time next year. I have some IFS brake calipers, rotors, and hubs for the scout. for all that don't know what that entails. the IFS hub set up gives you and extra 1.5" spaced out on each side and then you will also get vented rotors. so now i'll have more steering because i won't have to worry about the tires hitting the frame. and i'll need to add 1.5" spacers out back to make everything even
mudmaniac33
Post by mudmaniac33 on Jun 30, 2013 16:23:42 GMT -8
picked up a 2 coil 3rz and swapped out my distributor 2rz. its like night and day difference. The scout will actually cruise 50 no problem. before going highway speeds was 2nd gear almost on the rev limiter going up hills and 3rd gear cruising haha. can't wait to take it out to sand lake and hit the bowl now. I do need to figure out how to make a fan work because 3rz fans are quite a bit bigger than a 2rz fan so electric fan will probably be in my future and a v6 radiator
mudmaniac33
Post by mudmaniac33 on Jul 1, 2013 20:52:29 GMT -8
2 weeks ago I had one of our dogs get out due to police lack of respect for my property and not shutting gates that were closed while searching the area around my home looking for a stolen lap top which was found at the neighbors. so I have been thinking about my other dog Milo wheeling with me more. So I'm going to start making a mount to to hold the dogs harness. Diego was the brown and white one that was hit by a car. Milo is the black/grey and white one which we still have. Uploaded with ImageShack.usUploaded with ImageShack.us
mudmaniac33
Post by mudmaniac33 on Aug 19, 2013 18:04:51 GMT -8
mudmaniac33
Post by mudmaniac33 on Aug 19, 2013 18:17:21 GMT -8
and the damage. tan toyota- broke off 2 kc lights, broke rear bumper, dented up bed green toyota- faulty ignition switch, broke both rear driveline ujoints, transfercase ebrake skid plate bent ripping off caliper and driveline, dented bed and LF fender orange toyota- broken RR axle shaft, broken driverside extracab window, driverside dents and scrapes, red 4runner- broken rear third member, blown trunion bearing, broken hub, LF fender flat, headlight broke, both rear quarters beat SCOUT- broken rear driveline flange, bolt ripped out of transfercase for mount, rear differential studs pulling out of third, Both front fenders smashed, steering pump quit working, hole in windsheild, LR quarter panel beat, drivers door fell off due to hinge breaking, dents and scrapes everywhere. Uploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.com
mudmaniac33
Post by mudmaniac33 on Sept 2, 2013 12:28:42 GMT -8
Well we headed to Browns camp over labor day. Went and ran the bonus loop in the upper crushers and coming out the cage got tested. rolled it over 1 and 3/4 times it was a rush for sure I thought it only did 3/4 of a roll but everyone told me otherwise. ( i had my eyes closed for most of it) but had a great time bent my rear shackles and smashed some body panels but we flipped it over ran lower crushers then hit waterfall and can opener where got I got a little to rowdy and broke a hub and then my buddy broke an input shaft on his rear case trying to follow so we called it quits and I towed him back to the trailer. Uploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.comUploaded with ImageShack.com
Post by ljdude on Sept 2, 2013 15:40:26 GMT -8
rolled it over 1 and 3/4 times. then hit waterfall and can opener where got I got a little to rowdy [/quote] You rolled it and then you decided to go get rowdy. LOL!!!
mudmaniac33
Post by mudmaniac33 on Sept 2, 2013 18:54:51 GMT -8
ha I did the buggy line/ bonus loop up at the upper crushers got all the way to the top decided i didn't want to finish the loop and would take the bypass back down cause I did not want to roll off the ledge and well we can see how that worked out. I'm thinking I will wear my shoulder harness's all the time cause I was only using the lap belt when I went over. needless to say i was a little soar
