Post by myrradah on Jul 5, 2013 10:19:46 GMT -8
Hi all, Anyone know anyone who can bend this hunk of metal back so I can use it again? Two spots got bent. This is the plate: www.skidrowoffroad.com/Exhaust_12_JK.aspand here are a couple pics of the bent flanges.
Post by petee on Jul 5, 2013 17:34:56 GMT -8
why did you take it off?
Post by Wyldman on Jul 6, 2013 6:06:11 GMT -8
A little heat, an anvil and hammer should fix it right up.
Post by myrradah on Jul 6, 2013 9:39:39 GMT -8
It was rattling against the 360 exhaust and would have rubbed a hole in it eventually.
Post by ljdude on Jul 8, 2013 5:29:11 GMT -8
Like wyldman man said. A little heat and a BFH (Big Beepin Hammer) should do the trick.
Post by myrradah on Jul 8, 2013 17:35:18 GMT -8
Yes, these things you speak of I do not have....
Post by pistonschick on Jul 8, 2013 22:16:08 GMT -8
Hey Mike,
Darel has a bunch of BFH's and a few good sources of heat.
Bring it on over one evening this week or this weekend and he will help you out...
Crystal
Post by bigstuck on Jul 9, 2013 12:34:46 GMT -8
Did someone say that they needed heat at the crowders??? I can help.....
Post by myrradah on Jul 9, 2013 15:34:53 GMT -8
Did someone say that they needed heat at the crowders??? I can help..... We would need an appropriate sacrifice to go with any fire you build...
Post by pistonschick on Jul 9, 2013 16:26:03 GMT -8
Did someone say that they needed heat at the crowders??? I can help..... Dear Tom: Darel says, "yes", you may build a bon-fire at the house. Darel says, "no", you may not play with the plasma cutter. : )
Post by bigstuck on Jul 9, 2013 21:31:25 GMT -8
Did someone say that they needed heat at the crowders??? I can help..... Dear Tom: Darel says, "yes", you may build a bon-fire at the house. Darel says, "no", you may not play with the plasma cutter. : ) I'm confused is he worried I might accidentally comp cut mikes jeep? How else will the forties fit with no more lift so we can use it as a chase rig at koh?
Post by ljdude on Jul 9, 2013 21:40:01 GMT -8
Dear Tom: Darel says, "yes", you may build a bon-fire at the house. Darel says, "no", you may not play with the plasma cutter. : ) I'm confused is he worried I might accidentally comp cut mikes jeep? How else will the forties fit with no more lift so we can use it as a chase rig at koh? Where is that darn like button?!?! LIKE LIKE LIKE LIKE LIKE!!!
Post by petee on Jul 10, 2013 10:15:40 GMT -8
You had me at comp cut!
Post by myrradah on Jul 10, 2013 13:05:17 GMT -8
you guys are as bad if not worst than the company I work for with acronyms. To give you a clue to the severity of this - they have a web page you can go to to type in the acronym and find out what it is....or a list of them to pick the one that applies...
KOH? Comp Cut?
Post by bigstuck on Jul 10, 2013 13:08:26 GMT -8
KOH = KING OF THE HAMMERS COMP CUT = GIVE ME THE PLASMA CUTTER AND ILL SHOW YOU HOW BIG A TIRE I CAN FIT ON YOUR RIG IN ABOUT 20 MINUTES AKA THE REAR FENDERS OF THE RACE YJ WHERE IS GOES UP AND STRAIGHT BACK FOR MAXIMUM WHEELBASE STRETCH AND TIRE SIZE FITMENT.
