Post by ODJeepster on Feb 29, 2016 9:13:28 GMT -8
Looks really clean! Great work is that 1.75x.120? Yes it is, DOM.
Post by ODJeepster on Mar 3, 2016 9:16:03 GMT -8
Decided to finally replace the brake assembly in my rusty old Warn M12000. And while inside why not replace thrust washers and bushings. This is the drum surface that rides on the nylon bushings....needs some cleaning Here is the old brake assembly and all the rust that was around it I didn't take any pics of the reassembly after all the cleanup and new parts, but tonight I will reinstall and test.
Post by petee on Mar 3, 2016 20:22:29 GMT -8
Anddddddd?
Post by ODJeepster on Mar 3, 2016 20:40:42 GMT -8
And it works great!!! Free spools easy, powers in and powers out. Yay!!!!
Post by ExCabSwap on Mar 3, 2016 23:15:43 GMT -8
Very nice! What do you use to keep the cable from rusting? A cover? WD-40?
Post by ODJeepster on Mar 4, 2016 7:49:38 GMT -8
Very nice! What do you use to keep the cable from rusting? A cover? WD-40? The cable is galvanized so they typically don't rust. A rusty cable should be dicarded and replaced.
Post by bigstuck on Mar 4, 2016 21:15:41 GMT -8
Very nice! What do you use to keep the cable from rusting? A cover? WD-40? The cable is galvanized so they typically don't rust. A rusty cable should be dicarded and replaced. Also if you visit a place that sells a lot of cable they will have a cable lube/ protectant to help it last longer as well.
Post by ODJeepster on Mar 5, 2016 13:41:12 GMT -8
Mounted some back-up lights today
Post by petee on Mar 5, 2016 20:06:17 GMT -8
Those fit
Post by ExCabSwap on Mar 5, 2016 20:32:32 GMT -8
The cable is galvanized so they typically don't rust. A rusty cable should be dicarded and replaced. Also if you visit a place that sells a lot of cable they will have a cable lube/ protectant to help it last longer as well. I agree, and I'm replacing the rusty cable with this from 4WP/WARN.. Just wondering how to know if it's galvanized, or is that more of an industry standard now?
Post by petee on Mar 5, 2016 21:23:44 GMT -8
I'm going to put rope on soon
Post by ljdude on Mar 7, 2016 20:27:34 GMT -8
Mounted some back-up lights today Those should make some light.
Post by ExCabSwap on Mar 7, 2016 21:04:28 GMT -8
Looks like a nice option for tailgaters!
Post by ODJeepster on Apr 15, 2016 10:39:04 GMT -8
Recently picked up a few things for the Jeepster beginning of on-board air And some wheels for weld-on beadlocks
Post by ODJeepster on Apr 20, 2016 21:07:59 GMT -8
