Post by ODJeepster on Apr 20, 2016 21:10:59 GMT -8
Post by ODJeepster on May 6, 2016 13:52:00 GMT -8
Picked up some new shoes yesterday
Post by ExCabSwap on May 6, 2016 16:16:48 GMT -8
Those are beautiful
Post by ljdude on May 6, 2016 16:19:11 GMT -8
Score!!!
Post by ODJeepster on May 6, 2016 16:42:50 GMT -8
www.totalmetalinnovations.com shipped my weld on beadlocks so I should have those in a couple days. Turns out TMI is nearby in Albany, OR. Had the wheels run through the wheelabrator to clean of the white powder coating And then primered them. Now I'm trying to decide on color...
Post by ljdude on May 8, 2016 6:36:00 GMT -8
Bright orange.
Post by ljdude on May 8, 2016 14:55:02 GMT -8
Pink
Post by ODJeepster on May 8, 2016 15:07:57 GMT -8
Pink would look good with the OD green body. Lol. I'm kinda leaning toward gloss black wheels and gray rings. Also been on the fence about OD green wheels with gray rings, or gray wheels with OD green rings, or black wheels with OD green rings.
Post by ljdude on May 8, 2016 15:43:58 GMT -8
I like the grey wheel with the green rings.
Post by pistonschick on May 9, 2016 7:42:13 GMT -8
My vote is for OD green wheels with black rings or black wheels with OD green rings...
Post by ODJeepster on May 9, 2016 15:21:21 GMT -8
Fit and clamped inner rings Stitch welded to disperse heat and began bending and welding the integrated anti-coning tabs After seal welding ring to rim I buffed off with a grinder. Three more to go
Post by ODJeepster on Jun 16, 2016 8:51:41 GMT -8
Finished painting the wheels And the beadlock rings. Now to purchase valve stems and hardware, then I will mount my new rubber!!! I removed the front fender flares and trimmed 2 more inches.
Post by ljdude on Jun 16, 2016 14:58:43 GMT -8
Are you putting the flares back on or leaving it as is?
Post by ExCabSwap on Jun 17, 2016 2:24:24 GMT -8
Just saw the first pic of your build thread again when I opened this up.. You've done an awesome job, and come a long ways since then. I'm excited to see what's next with this build
