Post by ODJeepster on Jun 17, 2016 8:14:46 GMT -8
Are you putting the flares back on or leaving it as is? Yes flares are going back on. I had some serious tire slicing going on and decided I better remedy that before installing the new tires.
Post by ODJeepster on Jun 17, 2016 8:18:09 GMT -8
Just saw the first pic of your build thread again when I opened this up.. You've done an awesome job, and come a long ways since then. I'm excited to see what's next with this build Thanx Phil, I still need to build a swing-away tire/jerry can carrier. Also a belly skid is in my very near future
Post by ljdude on Jun 17, 2016 10:27:06 GMT -8
Just saw the first pic of your build thread again when I opened this up.. You've done an awesome job, and come a long ways since then. I'm excited to see what's next with this build Thanx Phil, I still need to build a swing-away tire/jerry can carrier. Also a belly skid is in my very near future You do need a jerry can holder. I have some ideas for the future that are going to push our fuel capacity limits.
Post by ODJeepster on Jun 17, 2016 11:18:43 GMT -8
Sounds interesting....I guess I will design a double can holder for the tire carrier
Post by ODJeepster on Jul 3, 2016 18:43:29 GMT -8
Added tubing to my roll cage today. Started triangulating the overhead section Added some tube gussets on the B-pillar hoop And a grab handle gusset for the passenger side
Post by hammerhead on Jul 11, 2016 7:26:04 GMT -8
Good work! Very nice.
Post by ODJeepster on Jul 11, 2016 11:14:53 GMT -8
Thank you
Post by ODJeepster on Aug 4, 2016 19:35:38 GMT -8
After abusing my worn out tires on Quack Attack I mounted the first two tires to the wheels Centered the outer ring Added bolts and air to seat the inner bead And couldn't resist seeing how it's gonna look
Post by petee on Aug 7, 2016 20:02:26 GMT -8
And?
Post by ODJeepster on Aug 7, 2016 20:19:49 GMT -8
And here they are mounted and on the Jeepster. Added one additional leaf to the front pack to help clear the new rubber.
Post by ljdude on Aug 8, 2016 19:58:48 GMT -8
Looks amazing!
Post by ODJeepster on Aug 15, 2016 18:55:42 GMT -8
Thank you
Post by ODJeepster on Aug 29, 2016 7:40:59 GMT -8
With the recent starting issues I have decided to add a push button for starting. Along with that is the beginning of rewiring the entire Jeepster. Started by removing the solenoid/ignition wire harness Drilled a hole in the firewall and added a grommet for protection Replaced the old crusty harness with this 12ga marine grade electrical cable
Post by ODJeepster on Sept 28, 2016 19:01:53 GMT -8
So I decided to order all new Autometer Z series gauges including Speedo, Tach, Air psi,Temp, Oil, Amps, and switches. And then I started making gauge panels using 10ga aluminum I also made an aluminum bikini top and painted it to match
