Post by ODJeepster on Oct 9, 2016 14:29:54 GMT -8
Some electrical goodies have been showing up for the rewiring project. Headlights, wipers, and heater switch Tach Air pressure Coolant Temp I am still at the drawing board for locations of the gauges and switches, also waiting on Oil Pressure, Fuel Level, and I haven't decided yet on either a Volt or an Amp gauge. What is the preferred gauge for electrical monitoring?
Post by petee on Oct 9, 2016 18:39:05 GMT -8
the pile of part is getting larger.....it's going to look good.
Post by ljdude on Oct 9, 2016 19:11:01 GMT -8
I liked the aluminum look on the top of the roll cage.
Post by ExCabSwap on Oct 9, 2016 20:50:43 GMT -8
Awesome gauges!
Voltage is a really great sign of battery life, as well as alternator function.
With a dual battery setup, I've seen some people monitor amperage, but unless you're worried that something will be drawing high current, it might not be worth it.
Tach-looks like you're already cruisin!
Post by ODJeepster on Oct 10, 2016 7:29:48 GMT -8
I liked the aluminum look on the top of the roll cage. I also liked the bare aluminum on top until towing it home from Hoodoo, the sun was reflecting off it into my rearview and it was like some @$$hole behind me had his light bar turned on lol
Post by ODJeepster on Oct 10, 2016 7:39:11 GMT -8
Awesome gauges! Tach-looks like you're already cruisin! Thanx Phil, the tach is what Autometer calls "Air Core" technology and it's normal for then to sit off of zero until hooked up
Post by ODJeepster on Oct 17, 2016 17:48:44 GMT -8
Dash progress
Post by ExCabSwap on Oct 17, 2016 21:38:50 GMT -8
NICE! Those Autometer gauges look right at home next to the old school fan switch!
Post by ODJeepster on Nov 6, 2016 21:14:32 GMT -8
I test fit the new gauge panel in the dash While at Napa I found some momentary push button switches to use for winch cable In and Out And also found some jump start lugs that will be a neat little feature Here is the winch controls mounted. Green lighted rocker switch to power the push buttons. Also made a harness for the gauge lights.
Post by ODJeepster on Nov 13, 2016 18:57:13 GMT -8
Progress on the headlight circuit. Wired in a relay for the low beams and a relay for the high beams to take take the load of the switch. I am using 12ga and 10ga because it's what I have. Once all the wires are run I will loom clean up the mess. I scored a great deal on this Odyssey Performance 31-800 battery. 1600 pulse cranking amps, 188 minutes of reserve power.....it's a badass!!!! Because of its size I decided to mount in the back Added the indicator lights and reinstalled the gauges. It'sgetting close to being installed in the dash.
Post by petee on Nov 15, 2016 7:11:28 GMT -8
Getting closer buddy, looking good.
Post by petee on Nov 15, 2016 7:12:02 GMT -8
Hurry up snow is coming
Post by ODJeepster on Nov 24, 2016 11:51:21 GMT -8
Happy Thanksgiving!!! Wired in a 150amp circuit breaker from the alternator to the ignition switch and headlight relays I tested the headlights, low beams and high beams both work. Then I wired the 12v+ and grounds at the back of the gauges and lights Unfortunately I soon realized that the location of the Speedo will not work because the speedo cable is almost touching the defrost vent. So I switched the Speedo and Tach locations and cut apart the freshly done wiring harness lol
Post by petee on Dec 3, 2016 20:14:05 GMT -8
Bummer
Post by ODJeepster on Mar 27, 2017 10:30:17 GMT -8
After running all new wires to the tail lights, I determined there is a bad socket in the original driver side tail light. Instead of trying to find OE or used (possibly with the same socket issue) I found some aftermarket ones that will look appropriate. Now I must make them fit as easy as possible without looking like a "hack" job lol. I started with some 1/8" aluminum, took some measurements 6-5/8"×2-1/2", did a little layout, and busted out the 2-1/2" hole saw. I then proceeded to use a cutoff wheel to cut between the circles And then test fit Painted OD Green to match. While paint was drying I connected the pigtails to the appropriate wires and then mounted using stainless hardware Tail light Stop and turn
