Post by ODJeepster on Oct 13, 2014 16:17:24 GMT -8
New shifter fit like a glove
Post by ODJeepster on Oct 13, 2014 16:19:28 GMT -8
Except the trim ring for the boot...may have to make one, we'll see what Jon at JB Fab has to offer.
Post by petee on Oct 15, 2014 14:08:43 GMT -8
Did you remove the detent ball on the front axle shift rail? To get front only. Or are you just looking for 2wd low option.
Oh and welcome to your new status as "applicant"
Post by ODJeepster on Oct 15, 2014 14:49:24 GMT -8
Did you remove the detent ball on the front axle shift rail? To get front only. Or are you just looking for 2wd low option. Oh and welcome to your new status as "applicant" ? I didn't know about removing the detent ball...thank you for that, I want "dig" I better look a little deeper.
Post by 7m4x4dude on Oct 15, 2014 20:25:24 GMT -8
dig
Post by petee on Oct 16, 2014 4:38:43 GMT -8
I'm here to help,( add more things you didn't know you needed to your list. )
Post by ODJeepster on Oct 21, 2014 9:32:13 GMT -8
Apparently if the Dana 20 t-case has the U pattern shifter, it doesn't require removing the detent ball for fwd only. I got lucky Woohoo!!! I can also run high range front and low rear, but not the other way.
Post by ljdude on Oct 21, 2014 13:57:45 GMT -8
I can also run high range front and low rear, but not the other way. All I'm hearing here is boom!!!!! ?
Post by ExCabSwap on Oct 21, 2014 14:55:15 GMT -8
I can also run high range front and low rear, but not the other way. All I'm hearing here is boom!!!!! ? I think he means that he can run high front by itself, or low rear by itself, but not the other way around. I don't think he means at the same time... well, I hope not...
Post by ljdude on Oct 21, 2014 17:26:22 GMT -8
All I'm hearing here is boom!!!!! ? I think he means that he can run high front by itself, or low rear by itself, but not the other way around. I don't think he means at the same time... well, I hope not... Same here! lol
Post by ODJeepster on Oct 21, 2014 19:54:13 GMT -8
Something will break with traction, in a slippery situation maybe not. I will never operate my Jeep like that. I am stoked for the fwd h & l...that plus a good ebrake will get used
Post by ExCabSwap on Oct 25, 2014 17:03:58 GMT -8
Post by ODJeepster on Oct 25, 2014 22:52:36 GMT -8
Yes it is...thanks for the link, I almost ordered one twice as much from a different outfit!!
Post by ExCabSwap on Oct 26, 2014 7:31:30 GMT -8
Well, those guys don't sell them anymore, but I think the page shows what you need in order to make it. Lemme know when you buy the parts because I wanted to buy a set too..
