Post by ODJeepster on Nov 23, 2014 9:22:05 GMT -8
Upgrading u-joint sizes now is also making progress to installing that D44 front that I'm workin on
Post by petee on Nov 23, 2014 11:39:42 GMT -8
If you go to a yj DL won't that be a 2" tube OD. That will make your rubbing problem fair worse.
Post by petee on Nov 23, 2014 11:42:22 GMT -8
Also wont you have to make shorten a YJ DLfor your current setup then shorten it again after installing the d44 do to the pumpkin being larger and therefore moving the pinion closer to the t-case?
Post by ODJeepster on Nov 23, 2014 12:20:40 GMT -8
If you go to a yj DL won't that be a 2" tube OD. That will make your rubbing problem fair worse. Excellent point!!! What I am seeing is by removing the uni-bearing setup the driveline will angle toward diff at the output shaft yoke instead of traveling straight for 8" or so and then dropping though a 3rd u-joint. In doing that moves the driveline further away from starter/bellhousing
Post by ODJeepster on Nov 23, 2014 12:28:13 GMT -8
Also wont you have to make shorten a YJ DLfor your current setup then shorten it again after installing the d44 do to the pumpkin being larger and therefore moving the pinion closer to the t-case? Another great point...I don't wanna shorten and balance it twice, so I better do some measuring...thanx Paul
Post by 4stgmby on Nov 23, 2014 13:26:33 GMT -8
I've decided to upsize the yokes on t/case and diff to 1310 and run a YJ driveline. It will eliminate that carrier bearing. i think i have a 1310, 10 spline yoke that should work for you, if you want it.
Post by ODJeepster on Nov 23, 2014 13:55:31 GMT -8
i think i have a 1310, 10 spline yoke that should work for you, if you want it.[/quote] Yes I want it, I will text you
Post by petee on Nov 24, 2014 13:13:50 GMT -8
I didn't relies it was two piece. That sounds like a great plan. You and I should talk before you get to far on your waggy front end. Might have an easier solution for you
Post by ODJeepster on Nov 24, 2014 15:10:02 GMT -8
I didn't relies it was two piece. That sounds like a great plan. You and I should talk before you get to far on your waggy front end. Might have an easier solution for you Yep I didn't realize that either until I pulled it out. I want to move forward soon on the front cuz I want disc brakes and a locker. Message me Paul and we can figure out when we can brainstorm
Post by ODJeepster on Nov 25, 2014 10:08:11 GMT -8
Thank you 4stgmby for the 1310 yoke!!!
Post by 4stgmby on Nov 25, 2014 21:22:12 GMT -8
you bet ya,
Post by ODJeepster on Nov 29, 2014 19:33:12 GMT -8
I apologize for the poor picture quality, my phone is nearing the end of it's life. Anyway with the nice weather this afternoon I decided to plug in my 4-1/2" grinder with a cutoff wheel and attack the Jeepster body. Rear wheel openings first...
Post by ODJeepster on Nov 29, 2014 19:35:19 GMT -8
And then the rocker panels (which were smashed already) to make room for the rock sliders
Post by ExCabSwap on Nov 29, 2014 20:17:57 GMT -8
You're brave, man! Lookin good
Post by ljdude on Nov 29, 2014 21:47:41 GMT -8
Just because Im sure that you dont have enough ideas already here's something else to get those creative juices flowing
