Post by 7m4x4dude on Oct 17, 2014 19:43:30 GMT -8
Not that you will do any major water crossing here in the north west. But you may find deep pudles.
The higher you can place them the better.also do at least 1 loop to allow moisture to collect and evap back out. And if you place it in a location where its not covered and may collect rain. Than bend the tip 90* back down to allow rain to drip off and not enter.
Post by ExCabSwap on Oct 17, 2014 23:24:55 GMT -8
I was thinking of bringing them both about as high as possible on the engine side of the firewall, with the loop there to sort of force evap any moisture out. But I don't know what to cap them with...
Post by ExCabSwap on Oct 18, 2014 23:20:53 GMT -8
Enjoying the weekend, and I got bored, so I thought I'd try to design something to send to the laser cutter monday... What do you guys think? 6" center-to-center. Should add a little height haha... What would give the best drop? I don't really care about height as much as getting more drop in the rear... Edit: Holes are .5" dia.
Post by ExCabSwap on Oct 22, 2014 17:02:28 GMT -8
Post by ExCabSwap on Oct 24, 2014 21:38:51 GMT -8
Back home where she belongs... now comes the fun part! Thinking of painting ideas... I'll probably leave everything nice and clean except for the valve cover... how do you guys feel about an american flag?
Post by ljdude on Oct 25, 2014 8:05:06 GMT -8
USA USA USA USA USA USA
Post by ODJeepster on Oct 28, 2014 5:52:22 GMT -8
You're getting fancy with it!!! I'm anxious to see the outcome
Post by ExCabSwap on Oct 28, 2014 8:44:17 GMT -8
You're getting fancy with it!!! I'm anxious to see the outcome Haha... me too! I just finished fitting on a few pulleys... I'm wondering if there's something I should do to my alternator since I've got easy access to it... Maybe an upgrade or something? Anyone familiar with 22R-Es have a suggestion? Something that I can do or get cheap? The wallet is gettin pretty thin Anyone have a pilot bearing puller I can borrow? Call or text: 8O1-783-5O68 Progress pictures tonight I hope..
Post by ExCabSwap on Oct 30, 2014 16:02:33 GMT -8
Well, I got sidetracked... Saw this beauty, and I couldn't resist...
With a little love, she's starting to look nice... First thing I did was check to see if the clutch still works, and it does Just set the compressor on the negative on my battery, and tapped the wire to the positive, and the clutch clicked right over.
Then I had to hop on AutoCad to get the bracket ready:
So the piece on the left is the engine side, the piece on the right is the york side, and the 4 holes in the center of each plate are to line it up before welding the plates together.
This may delay the build a day or so, but it will be worth it.
I was cautioned that running the compressor will eat what 'little' power my engine makes, and I assure you, I won't be running it when not in use. I have a nice OBA tank that will be used.
Here's a diag. I stole from Kilby:
Some of the components might change, but this is the general idea...
Feel free to let me know if you see a kink in my plan. I'm always open to suggestions.
Post by ExCabSwap on Nov 1, 2014 21:32:54 GMT -8
Well, I'm almost ready to put the motor back in. I was delayed a few hours because I was getting my injectors cleaned! Professional Injector Kleaning did a really nice job. I won't be able to fully recommend them until I get the motor running, but from what I can see, they did a superb job. Military discount (10%), and he had my injectors back to me the same day!
Before:
The guy said that my cold start injector didn't even work. He had to put it through a few ultrasonic cleanings just to see a trickle. When all was said and done, he gave me a call (same day), and let me know that one of the spare injectors I gave him he wasn't going to do because it was too damaged, and he couldn't warranty it. That's right, all the injectors have a 1 year warranty!
Anyway, here's what I picked up After:
Full clean and rebuild, $22.50 ea. and I bought 4 extras a while back as spares for $3 ea.
Really great investment, considering that new, each injector was more than $150, I decided to support a fellow local small business..
Anyway, now that the intake is on, I'm ready to drop in the motor. I'm just waiting on the laser cutter to finish up with the adapter plates I sent them so that I can mount on the York, get the length for the belt, and bolt it on. Still looking for a good coalescent filter, and where to mount the OBA tank, but I'm hoping to at least be done before the next meeting so I can show off the goods
Post by ljdude on Nov 5, 2014 5:06:43 GMT -8
Good job!
Post by 7m4x4dude on Nov 5, 2014 22:08:37 GMT -8
Sweet your doing a great job!
