Post by hammerhead on Jun 9, 2016 11:31:29 GMT -8
I've been thinking about posting a build log for both YJ's I'm building up. This one is my wife's. I haven't done a great job of getting pictures the whole time but there's a few to capture progress. The work list itself is a lot of little stuff mixed in with the big, no priority just a fairly accurate order in which it happened, oldest at bottom. The work has been accomplished by my wife, my dad and myself.
Project TINA Photos
Work List-
Needs:
Under hood light, replace with LED array?
Turn signal switch reset
Tuneup
brakes?
Exhaust leak/install new cat
Repair sunvisors
Wants:
Hard top window molding
U-bolt skid front
Auto-locking Diffs
Replacement drivers seat
Replace dash speakers
Completed:
CB radio & antenna-done
rear bumper with spare mount -done
paracord door straps -done
Replace am/fm antenna -done
15*8 steel rims -done
33" tires -done
Winch cover -done
winch rope dampener -done
shackles -done
Tree savers -done
Snatch blocks -done
Shift indicator -done
Roll bar handles -done
Rear extended brake line -done
Wired front speakers -done
Rewired speaker bar -done
Stereo protection -leaving as is
Strip console/sub, paint, add armrest -done
Amp move/protect -done
Winch -done
Replace forward drive shaft rear u-joint -done
Extended brake lines front L&R -done
Deflators -done
Air pump -done
Side step or sliders -done
Front bumper/winch mount -done
removed stereo, speaker bar, sub and all related wiring -done
4" lift -installed
4" extended shocks -done
4" lifted leafs springs -done
4' extended sway links -done
4" track bar mount -done
4" drop pitman arm -done
Repair 4x4 vacuum system -done
Repair power steering missing bolts/belt tensioner -done (pick n pull vancouver parts)
Battery hold-down -done
Pad roof/rollcages/speaker bar -done
more bulbs and bulb holders -done
Hazard relay -done
Wire Electric Fan delete Stock clutch fan -done
Drivers door lock, rekeyed and rebuilt -done
New cabin temp control cable -done
Fix cabin vent tube disconnect -done
Right rear reverse bulb -done
Front drivers turn bulb - done
Remove car alarm sensors and wiring -done
Ratty extra wiring -done
Oil change/check diff/transaxles/tranny -done
Speedo bulb -done
4wd bulbs -done
Soft top or bikini -done
Tina Install -done/redone
Project T.I.N.A. TERRAIN INTENSIVE NATURE ACCESS
Project TINA Photos
Work List-
Needs:
Tuneup
brakes?
Repair sunvisors
Wants:
U-bolt skid front
Auto-locking Diffs
Completed:
33" tires -done
Winch cover -done
shackles -done
Tree savers -done
Snatch blocks -done
Winch -done
Deflators -done
Air pump -done
4" lift -installed
Hazard relay -done
Speedo bulb -done
4wd bulbs -done
