Post by Wyldman on Aug 12, 2009 17:25:52 GMT -8
As of the early morning of the 11th of August my Warn 9.5 TI winch was stolen right off the front of my Jeep in my drive way.
Suggestion: Make sure your winch is fastened down using something other then the factory bolts. Weld the bolt heads or the winch plate to the bumper.
You should always check the mounting points periodically the make sure it hasn't come loose over time. By welding the mounts, it will be a safeguard for mount failure and a major theft deterrent.
I hope my experience can become someones education.
Until Next Time... Enjoy! Wyldman
Post by trdoffrd on Aug 12, 2009 17:32:43 GMT -8
that sucks!!! i cant believe they are going that low as to just take a winch. Ive always used tamper proof screws an bolts on my rig an it seems to help..
Post by racincowboy on Aug 13, 2009 11:24:27 GMT -8
Sorry to hear about your winch wyldman. Hopefully you can track it down I will keep my eyes and ears open does it have anything special on it that sets it apart. Something that you may have a picture of?
Yours was a 9.5 ti right?
Post by Wyldman on Aug 13, 2009 17:21:10 GMT -8
Yes, it was a 9.5 TI and the special thing about it was an additional steel cylinder attached just after the end loop to keep the loop from going into the fairlead. I had the new cable made with that on it.
Post by fivendime on Aug 15, 2009 7:42:56 GMT -8
Thats a bummer. I will keep my ears open through the crowds to see if I hear about it.....you never know who may slip.
My suggestion is to get a couple of the easily accessible bolts and tack the nuts to the bolt. Or bugger the treads with a tack weld. Like I told Doug, the guy I bought my XJ motor from had someone steal his winch right from the front of his house while he was home. I would like to get my hands on these kinds of trash. We work hard for our toys.
Post by fivendime on Aug 15, 2009 7:45:52 GMT -8
Another thought...........bring it to my house and I'll weld it for free for ya!
Post by Wyldman on Aug 15, 2009 20:19:42 GMT -8
Thanks, FnD I might take you up on that.
Post by fivendime on Aug 30, 2009 9:02:23 GMT -8
HEY, when am I going to weld that plate on for ya!
