Post by hootie on Jan 22, 2009 15:19:37 GMT -8
Post by hootie on Jan 22, 2009 15:21:58 GMT -8
Post by Jon on Jan 31, 2009 21:28:57 GMT -8
Post by hootie on Feb 5, 2009 10:04:35 GMT -8
Jon's winch rebuild link goes to a very detailed set of instructions.
I plan to use infor from all three postings when I do my winch. The first two postings are a more simple set of instructions and may clarify the more detailed third posting.
popeye
Post by popeye on Feb 6, 2009 10:30:24 GMT -8
Jon's winch rebuild link goes to a very detailed set of instructions. I plan to use infor from all three postings when I do my winch. The first two postings are a more simple set of instructions and may clarify the more detailed third posting. i thought yours worked fine?
Post by hootie on Feb 7, 2009 13:00:21 GMT -8
no,, mine does not free spool. only power in power out.
and it needs to be resealed.. and since it needs to be resealed it probably needs the mud from saint helens mud bog cleaned out because it went under at least three times that day.
Post by rockrawler on Aug 17, 2010 20:11:32 GMT -8
If you need parts i went through central 4x4. Warn used to either give you the little things or bill you and put them in the mail. Now they want a dist. I went and had mine powdercoated while it was apart(thanks to mr.powdercoat)
