Post by shanandry on Nov 22, 2009 15:18:06 GMT -8
I just did a transfer case swap on my Grand Cherokee to get rid of my roasted 249.(full time 4wd-N-4lo transfer case.) I swapped in a 242(yay 2wd, 4part time, 4 full time, N, 4lo.) but the rear drive shafts I have are the wrong lengths. The shaft from the doner jeep is a little too short, and the one that came out of my jeep is a little too long. (face palm. lol) The shorter one only has about an inch before it pulls off of the tail shaft on the transfer case and falls off. I managed to find a 242 with the same length input shaft, the same gear cut, and all that, so that part was easy. But now I am stuck until I can get my drive shaft right. I want to get the longer one shortened about an inch, but I don't know where to take it. Can anyone recommend a place here in Vancouver?
Post by fry on Nov 22, 2009 17:10:28 GMT -8
ken at six states in the driveline shop. they are in portland on columbia blvd east of north side ford at about 57th.
redxj
Post by redxj on Nov 22, 2009 20:23:57 GMT -8
ken at six states in the driveline shop. they are in portland on columbia blvd east of north side ford at about 57th. Careful there are 2 Ken's there and you want the Ken in driveline. He's the only one that does my DLs and I've had mulitiple on my xj. Broke 3 rear this last summer. I've seen him a lot lately. Good guy though. Six States Distributors Inc www.sixstates.com6011 NE Columbia Blvd Portland, OR 97218-2968 (503) 249-1010
Post by shanandry on Nov 22, 2009 22:02:30 GMT -8
Thanks guys!
Post by shanandry on Nov 22, 2009 23:50:41 GMT -8
The shaft that was attached to the 249 was 1/8" too long to bolt in. The one that we got with the 242 is too short. Only about 1" of the transfer case output shaft is inserted into the yoke. I'm scared to drive it like that lol. Anyone know how much room I need in the slip yoke? Is 1" enough compression room? I was thinking I should get the shaft that was on the 249 shortened 1-1.25"? I have never done this stuff before, so the more brains I can pick the better...
Post by racincowboy on Nov 23, 2009 8:58:20 GMT -8
x2 On ken in the driveline shop at Six States. And its actually just west of Northside Ford in that little strip mall.
As far as how much slip yoke to have If it was me I would just measure from yoke to yoke and let the pros take it from there. they will make sure you have enough. I am sure there will be questions on how you use it ect. They are great guys they will get you all fixed up.
If I remember right shortening a DL is cheaper as well. Seems like I am always going the other way around.
Post by shanandry on Nov 23, 2009 9:10:05 GMT -8
I would think that the wrangler DL are more sensitive to changes in your rig. They are so short! I think I am going to putter around in the empty parking lot across the street in 4 part time, with the rear DL out. I need to fire it up!
Post by shanandry on Nov 23, 2009 10:28:19 GMT -8
Thanks ya'll. I dropped it off, and Ken said he will try and get it done by tomorrow. Good deal!
redxj
Post by redxj on Nov 23, 2009 20:55:31 GMT -8
x2 On ken in the driveline shop at Six States. And its actually just west of Northside Ford in that little strip mall. As far as how much slip yoke to have If it was me I would just measure from yoke to yoke and let the pros take it from there. they will make sure you have enough. I am sure there will be questions on how you use it ect. They are great guys they will get you all fixed up. If I remember right shortening a DL is cheaper as well. Seems like I am always going the other way around. Lance Ya it sounds like she/you dont have the SYE(Slip Yoke Eliminator)!! That you make it so much simpler with all the DL vibs you say you have. Why try to figure how much is slips in/out of the TC? MAKE IT FIXED.
Post by shanandry on Nov 23, 2009 21:11:04 GMT -8
Lol, if only i had enough lift (or cash haha) to need an SYE! I just had to get the booger shortened, because the new t-case is. The old TC was getting pretty bad, and the front end was starting to bind up and hop/squeal. I couldn't part the darn thing worth a squat either. This will make is so much better.
Post by beatcj on Nov 24, 2009 10:40:15 GMT -8
Ya it sounds like she/you dont have the SYE(Slip Yoke Eliminator)!! That you make it so much simpler with all the DL vibs you say you have. Why try to figure how much is slips in/out of the TC? MAKE IT FIXED. Meh. With 106 inches of wheelbase, he can get by without it. It would be nice on a 'wheeler, but there are other places to throw money on a mainly street rig.
Post by shanandry on Nov 24, 2009 15:20:09 GMT -8
Just wanted to say thanks again. Ryan installed the DL today, and once we got the linkage adjusted I took it out for a spin. Woohoo-no more binding! My yard is a little worse for the wear though. haha! Ryan was doing burnouts in the yard while I watched to check if it was still stuck in 4part time, or if we finally had it adjusted right and got it into 2wd.
Post by racincowboy on Nov 24, 2009 15:47:12 GMT -8
I was talking about the drive lines in my race truck not my jeep. But it doesnt really matter. Mine works just great in both.
Post by kenny811 on Dec 3, 2009 12:51:30 GMT -8
Six States is the place to go!! For whats its worth, my XJ as 6" lift and im not using a SYE. I've never had a problem from that or with vibration. But I also made sure with 6" lift my wheel base is right at 101 3/8". It drives awesome.
redxj
Post by redxj on Dec 3, 2009 20:27:14 GMT -8
Six States is the place to go!! For whats its worth, my XJ as 6" lift and im not using a SYE. I've never had a problem from that or with vibration. But I also made sure with 6" lift my wheel base is right at 101 3/8". It drives awesome. I would agree with that cuz on my 88' &89' had 6" on both of them and didn't need it. But do have friends that have mid 90's to 99 and they all needed the SYE. And on the 95' that I have now I had to do it at 5.5"
