Post by TORX on Nov 29, 2009 21:44:21 GMT -8
After this weekends trip I quickly realized I can no longer transmit a clear message. I can pick up others message's crystal clear, but when I try to transmit I come out gargled and weak.
Any thoughts what the problem may be? I've had my CB setup in the Jeep for 4 years and have never had a problem. I did put a new battery in the Jeep last week, but I don't see how that could effect anything. I made sure all the connections were tight.
I have not had the radio tuned with an SWR meter, but like I said I've never had a problem with transmitting or receiving. I was told the mics can go bad overtime, is this true?
Thanks in advance.
Post by trdoffrd on Nov 29, 2009 21:49:35 GMT -8
yes mics can go bad over time, they are cheap to replace
Post by TORX on Nov 29, 2009 21:58:29 GMT -8
I guess I'll try and find someone to swap mics with, and see if that's the problem.
I used to get all my CB parts from Joes, but since they closed where's a good local place for CB supplies?
Post by trdoffrd on Nov 29, 2009 22:02:52 GMT -8
you can get power mics at jubitz as well as other stuff
Post by tonka on Nov 30, 2009 7:35:04 GMT -8
I have a swr meater. I do not know how to tune with it. It was my fathers. I got lucky on mine I just installed it and it worked. I have a few mic's as well. what brand is your CB how manny pins on mic cord.
Post by fivendime on Nov 30, 2009 8:43:52 GMT -8
My dad's XJ did the same thing, slowly went out. Pull your Coax cable out of the back of your CB head unit and see what it looks like. My dads was melted away from years and years of use. Mic was fine. A new cable was all it took.
Plus if you need a CB tuned I have an SWR meeter and I tuned mine. Got it to near perfect swr's, I could help you tune yours if needed.
Post by TORX on Nov 30, 2009 11:45:55 GMT -8
It's a Midland radio with I believe a 4 pin mic cord.
I'll try and do some troubleshooting this week and see what I come up with. Hopefully it's a cheap and easy fix. I just hate not being able to communicate while out on the trail.
Post by Jon on Nov 30, 2009 12:17:36 GMT -8
After this weekends trip I quickly realized I can no longer transmit a clear message. I can pick up others message's crystal clear, but when I try to transmit I come out gargled and weak. DUDE!!!! You got my CB!!! ;D I have this same issue... or so I am told because I can hear everyone clear, but they can't hear me. I am thinking its an electrical issue, and that I may have fried the radio. I am connected straight to bettery (rather than a fuse) and do not have an inline fuse. That would be the only difference between the CB in my jeep, and the CB being in the FJ Cruiser. I may pick up an inline fuse and give that a shot to see if it filters out some of the electrical noise. I may also try finding a real ground (for the electrical, although the one I am using seems to work). I may also shave some powder coat off my cb mount to improve the ant ground. If it still doesn't work, I may take it all over to Vancouver John and have an expert look at it. If I fried it by having to high of an SWR while transmitting.... I may get a new radio. I may install a smoke signal kit on the Jeep instead. I may get this done by the new years ;D
redxj
Post by redxj on Nov 30, 2009 15:00:57 GMT -8
I have a swr meater. I do not know how to tune with it. It was my fathers. I got lucky on mine I just installed it and it worked. I have a few mic's as well. what brand is your CB how manny pins on mic cord. I also have a SWR meter and do know how to use it. BUT it really depends on what kind of stick you have? Some have more adjust ability than other, but that pends on the radio you are using and how far you want to get out.
redxj
Post by redxj on Nov 30, 2009 15:37:00 GMT -8
After this weekends trip I quickly realized I can no longer transmit a clear message. I can pick up others message's crystal clear, but when I try to transmit I come out gargled and weak. DUDE!!!! You got my CB!!! I have this same issue... or so I am told because I can hear everyone clear, but they can't hear me. I am thinking its an electrical issue, and that I may have fried the radio. I am connected straight to bettery (rather than a fuse) and do not have an inline fuse. That would be the only difference between the CB in my jeep, and the CB being in the FJ Cruiser. I may pick up an inline fuse and give that a shot to see if it filters out some of the electrical noise. I may also try finding a real ground (for the electrical, although the one I am using seems to work). I may also shave some powder coat off my cb mount to improve the ant ground. If it still doesn't work, I may take it all over to Vancouver John and have an expert look at it. If I fried it by having to high of an SWR while transmitting.... I may get a new radio. I may install a smoke signal kit on the Jeep instead. I may get this done by the new years ;D You never want to leave a power source un-fuzed! protect it.
Post by fivendime on Nov 30, 2009 21:44:46 GMT -8
I may install a smoke signal kit on the Jeep instead. I may get this done by the new years ;D What about when those blizzards come in.......your going to need a lot of smoke man!
Post by TORX on Dec 7, 2009 20:09:05 GMT -8
DUDE!!!! You got my CB!!! Never would have thought your CB was contagious. ;D Well I picked up a new antenna today (tunable firestik). I tried a different mic this weekend and I think I was able to transmit out. I didn't have any static feedback while transmitting, but unfortunately I didn't have anyone to pick up the message so I'm not sure how clear it came out. I'm going to try and pick up a new mic in the next couple days, and get the new antenna tuned (Joey does your offer still stand?). Hopefully I'll be transmitting again by this weekend.
Post by bigstuck on Dec 7, 2009 20:24:06 GMT -8
DUDE!!!! You got my CB!!! Never would have thought your CB was contagious. ;D Well I picked up a new antenna today (tunable firestik). I tried a different mic this weekend and I think I was able to transmit out. I didn't have any static feedback while transmitting, but unfortunately I didn't have anyone to pick up the message so I'm not sure how clear it came out. I'm going to try and pick up a new mic in the next couple days, and get the new antenna tuned (Joey does your offer still stand?). Hopefully I'll be transmitting again by this weekend. good to meet you today in the store. Let me know if you need any more help ill do what I can.
Post by fivendime on Dec 7, 2009 21:06:17 GMT -8
Sure thing! I only ask one thing. When you tune CB's you sometimes have to raise or lower them more then what the antenna adjustment will allow for. Usually this isn't much of a problem because as long as you dont mind it we can get it close. If you want it really good it can take a bit of time. It really all depends. So I guess what I am trying to say is if you have a spring under the antenna to raise it or a way to lower it like flip the bracket that's cool, if not dont worry we can get it close! I will be at the gathering tomorrow if you want we can do it then? Shouldn't take much more then half an hour or so, and there is a nice open spot in the ice rink parking lot. Let me know and I will bring the box and cable.
Post by TORX on Dec 7, 2009 21:44:33 GMT -8
good to meet you today in the store. Let me know if you need any more help ill do what I can. Small world, I'll definitely let you know if I need anything.
