Post by fivendime on Mar 31, 2010 21:14:27 GMT -8
This is a quick run down of the suspension Torque Settings you should inspect every so often if you take your XJ off road.
Subframe to Unibody nuts= 50 ft. lbs. Transfercase Mount nuts= 15 ft. lbs. Track Bar bracket to Unibody= 92 ft. lbs. Track Bar bolt at Axle= 74 ft. lbs. Track Bar bolt at Unibody Bracket= 80 ft. lbs. U-Bolts= 90 ft. lbs. Leaf Spring and Shackle bolts= 120 ft. lbs. Lower Shock bolts= 46 ft. lbs. Upper Shock Barpin bolts (rear only)= 17 ft lbs. Lower Control Arm nuts= 120 ft. lbs. Lug nuts= 85-120 ft. lbs. (depending on your wheels)
I will add to this later but this is just what the lift company suggests with my lift and though that this would help for those of you who dont have the specs for there lift setup. If you have a stock rig please look at your service manual for stock torque settings.
