Post by thekid on Dec 2, 2013 14:26:59 GMT -8
Port/Polished Cummins 4BT (3.9) 175-200hp 350-400ft/lb
This motor was recently rebuilt by local diesel shop for my project truck. The motor has new bearings and gaskets. Bosch rotary fuel pump. Injectors have been cleaned and tested. Injection pump has been resealed and modified with a dynamic timing advance kit and an upgraded fuel pin. Engine comes with harmonic balancer, new AC Compressor, new Cummins starter, used alternator, as well as a bracket to mount compressor on. Engine will also come with the AMSOIL bypass housing and motor mounts. Engine needs thermostat/gasket, and belts. Motor was run on test stand in shop after assembly with no issues. Have receipt. $6,000 for motor and all accessories, firm on price, non-negotiable, no trades.
4BT -- NV4500 Transmission adaptor $150
New Dodge NV4500 Bellhousing $350
NP205 Transfer Case
Freshly rebuilt with new seals and gaskets. All bearings inspected and in perfect working order. Installed with new Offroad Design twin stick shift rails. Comes with the Dodge 29 spline input shaft and adaptor as well as the racetrack adaptor to bolt to a NV4500 transmission. $1,100 for setup, price is firm.
Dodge NV4500
This transmission was purchased along with the listed NP205 transfer case. The 4th and 5th gears were damaged upon inspection. I have purchased new gears, shafts, seals, bearings, and syncro rings to rebuild unit but labor has not been performed yet. All parts were purchased from Cascade Component Parts in Portland, have all receipts. Transmission for sale as is for $1200, or completed for $1,500, no core charge either way.
Dodge Dana 44HD 3.73 front axle (Passenger side drop)
This axle has brand new gears (3.73), seals, new factory ball joints, new set of loaded brake calipers, and brand new Warn heavy duty locking hubs. Axle has been converted to 8 lug. Axle and gears were assembled by Leonard's Offroad shop. $1,000 firm.
Chevy Dana 60 3.73 Full Floating Rear axle with ARB Air Locker
This axle was also setup by Leonard's Offroad shop. Has brand new gears (3.73) and new seals and bearings. $1,000 firm.
If you buy for front and rear axles I'll give you 5 chevy steel wheels/tires for free, otherwise the set is $100.
I am not able to finish my project vehicle so I'm selling all of the big components. All prices are firm, I have receipts for all purchases. I'm looking for a Gen 3 Toyota 4 runner that I may consider as partial trade pending an inspection at my expense.
Call or text Mike at 503 806 3922, or me at 503 953 3085 or PM me back, and ill relay for you if you want. i know the guys who has the stuff, and he is a strait shooter. the parts are in a shop out in gaston, but im sure we could arrange delivery if needed.
NP205 Transfer Case
Dodge NV4500
