rizon
Post by rizon on Mar 28, 2010 17:14:41 GMT -8
After a day of mudding, on my way down the mountain, my TF999 will not shift out of 1st. Park, reverse, nut, and L seems to work fine. When the lever is in 2 or D it just stays in 1st gear.
Now I was in a lot of water. Does not look like any is in the ATF fluid. Yes I checked the fluid. Not super red, and not black, or inundated with any metal flake.
Could this just be a sensor? What should my first step be? Change the fluid? Drop the pan and change the filter?
Thanks for your help. Has anyone else had this problem?
rizon
Post by rizon on Mar 28, 2010 17:15:48 GMT -8
Drove all the way home (from Warren to Vancouver) going 25mph btw. That sucked!
Post by hootie on Mar 29, 2010 19:45:29 GMT -8
I have had this happen on a crystler mini van.. was the limp mode.. your tranny may have a malfunction and this is the emergency mode. On my van... I was able to pull over... turn key off and on about 5 or 6 times,,,, then restart the van and it would work for a week or so.. this time decreased until it did not any longer work.. then,,, bye bye van.
Post by tonka on Mar 30, 2010 4:40:57 GMT -8
If you have not figured it out. I can help. Call me at my shop I have fixed many of them (503)788-6355 ask for Pat I am moving shop and my phones are messing up alot so keep trying
rizon
Post by rizon on Mar 30, 2010 17:37:41 GMT -8
If you have not figured it out. I can help. Call me at my shop I have fixed many of them (503)788-6355 ask for Pat I am moving shop and my phones are messing up alot so keep trying If you have not figured it out. I can help. Call me at my shop I have fixed many of them (503)788-6355 ask for Pat I am moving shop and my phones are messing up alot so keep trying Thanks Tonka. I took it to a local trans shop and they said I need a rebuild. I decided to try changing the fluid and filter first. I did that today. The filter was nasty. Not much metal flake to speak of. I just took it on a short test drive, only about 3 miles, and so far it is much better...........not perfect but better. I will drive it a few more times and flush the fluid once more. If this does not fix it I may give you a call Pat.
