Post by pistonschick on Sept 21, 2010 22:29:56 GMT -8
The best drive line guy that I know of is located in the Driveline Shop at Six States Distributors, Inc. (east door of building)
They are located at 6011 NE Columbia Blvd - Portland, OR 97218
Phone: (503) 249-1010 or Toll Free (800) 547-7024
Ask for Ken Nevills - Drive Line Manager
Tell him Crystal sent you to get the best deal (right Hootie?)
Post by joshwho on Sept 22, 2010 4:00:27 GMT -8
Six States is definetly the best all around driveline shop! I have sent a ton of shafts to them for shortening and lengthening and the balance is RARELY bigger than a dime (which is the way that it's really supposed to be, because otherwise it means it's crooked, or it's not straight), but for HIGH horse stuff (700+ wheel horsepower) I've always used Driveline Service... (not that I've EVER ran into problems with a Six States shaft that didn't get bent from HITTING something) BUT I've never used either of them for my thick tube (.120"+) shafts (if you need THAT thickness straight enough to run down the road at highway speeds I'd see what Driveline Tech has to say after checking with the the first two), but I'm sure they could do that stuff too.
Overall Six States is definetly the place to go (for 95% of the people 99.99% of the time)!
Post by pistonschick on Jan 30, 2011 17:56:02 GMT -8
Six States is definetly the best all around driveline shop! I have sent a ton of shafts to them for shortening and lengthening and the balance is RARELY bigger than a dime (which is the way that it's really supposed to be, because otherwise it means it's crooked, or it's not straight), but for HIGH horse stuff (700+ wheel horsepower) I've always used Driveline Service... (not that I've EVER ran into problems with a Six States shaft that didn't get bent from HITTING something) BUT I've never used either of them for my thick tube (.120"+) shafts (if you need THAT thickness straight enough to run down the road at highway speeds I'd see what Driveline Tech has to say after checking with the the first two), but I'm sure they could do that stuff too. Overall Six States is definetly the place to go (for 95% of the people 99.99% of the time)! Yep, I agreee, for the really BIG ponies 700+ - Driveline Service has a little bit of an edge on Six States - but our Six States drivelines behind our 500+ ponies as well as our trail rigs seem to be taking the pressure just fine... I am taking Bruiser's rear driveline in to Six States on Monday for alterations to accommodate the new Atlas II transfer case. Ken is just the best to work with!
