Post by myrradah on May 5, 2013 14:28:48 GMT -8
Man I am telling you, nothing for a 2012 is jsut a bolt in option. All work instructions etc are all for 2011 and older and it doesnt work with the 2012's very well. Then there is the differences between a manual and a automatic and what firewall holes to use...if any. But, its in, running and works good Tommy - I used the 5 foot 200 PSI red air pressure hose from Harbor freight and its the perfect length. No leaks, has a swivel on it so there are no crazy bends in the line and I dont see it coming loose at all.
Post by petee on May 5, 2013 15:46:49 GMT -8
Nicely done sir.
Paul
Post by racincowboy on May 5, 2013 16:52:08 GMT -8
Nice work on the install. One thing you might consider is finding a cap (of some kind) to put over the connection in the bumper to keep weather and dirt out.
I have had good look with PCV caps fitting over those chucks. They just slip over and the machine surface on the slider part of the chuck holds them on without an issue. The chucks on our dump trucks are mounted horizontally and the caps stay on just fine.
Just a thought to stave off future issues.
Post by myrradah on May 5, 2013 23:36:36 GMT -8
Nice work on the install. One thing you might consider is finding a cap (of some kind) to put over the connection in the bumper to keep weather and dirt out. I have had good look with PCV caps fitting over those chucks. They just slip over and the machine surface on the slider part of the chuck holds them on without an issue. The chucks on our dump trucks are mounted horizontally and the caps stay on just fine. Just a thought to stave off future issues. Lance Yup, I am currently using the cover that was on the pressure switch, but I will look at the PVC covers you mentioned. Ill need something a little more rugged.
Post by ljdude on May 6, 2013 21:26:01 GMT -8
Nice work. Air and a CB radio are those things that I thought was overrated until I had it. Now I think all vehicles should have them!
thebrat
Secretary
"FOUR WHEELIN" An Insane, Incontrollable, Human Psychological, Pathological LIFE STYLE.
Post by thebrat on May 7, 2013 9:02:39 GMT -8
nice looking job ;D i would agree with everyone else on the cover to keep drit and trash out.
