Post by bchutchens on Dec 2, 2009 15:46:26 GMT -8
I was wondering if anyone had any idea o how to fix static on my radio in my work truck. This is on the AM side of the dial only.It's a newer radio and seems to only do it when I turn on the blinkers and step on the brakes. Could this be a ground thing? And what should I do. The diesel shop never seems to be able to fix it.
Post by jaketino on Dec 7, 2009 12:03:14 GMT -8
GET A NEW RADIO!!!
Post by shortbus on Dec 8, 2009 9:15:19 GMT -8
I agree with your son.
Post by bajamike560 on Dec 11, 2009 11:29:55 GMT -8
Cut the muffler off...LOL I have the same problem in my 99 ford PU with the stock unit. Try www.ccradio.com I think is the site. Mike
Post by racincowboy on Dec 11, 2009 12:44:10 GMT -8
Its a bad ground somewhere. I would venture to say its right around the radio and something is loose. Pull it and take a look. If you dont like that radio and you are that far might as well put in a new one that you do like.
Thats a pretty common problem in big trucks.
Post by hootie on Dec 11, 2009 16:40:03 GMT -8
I would change the brakes,,, and not use the turn signals.
( but that is just me. )
Post by bajamike560 on Jan 20, 2010 22:30:21 GMT -8
Did you find the problem with the noise in the radio??
Mike
Post by bchutchens on Jan 28, 2010 18:04:39 GMT -8
Still have it, shop worked on it but it still is a problem.
Post by bajamike560 on Jan 29, 2010 1:22:48 GMT -8
What kind of truck is it? Like said before it might be a ground issue, or a plane (spelling) issue with the CB antinas (spelling) not getting above them for the reception... ?? Are you holding your mouth just right and or do you have filling's??? Sorry had to put some fun in it.
Mike
Post by Jon on Jan 29, 2010 9:32:28 GMT -8
You need to use the fine adjustment tool.
