Post by 400sbk25 on Jan 17, 2010 21:28:40 GMT -8
3.73 lsd w/ disk brakes out of a v8. factory traction bar mounts 200obo. Pm if you have questions.
Post by fivendime on Jan 17, 2010 21:38:00 GMT -8
This should fit the stock Cherokee right? Or is it wider or narrower?
I am very interested.
Post by 400sbk25 on Jan 18, 2010 12:53:35 GMT -8
it is a common swap into cherokees and is the same width if i remember. I kno a dana 30 swaps right into a ranger and the explorer 8.8 is same width as a stock ranger.
Post by shortbus on Jan 18, 2010 15:26:37 GMT -8
it is the same joey just have to cut and change the perches if that is the one out of the exploder
Post by czjeeper on Jan 18, 2010 16:31:58 GMT -8
It is a smidge narrower than the YJ dana 35 (I think 1" on each side). I'm pretty sure it's the same case for the XJ as well. I'm in the middle preparing to swap one into my YJ. If you get the '96 and later, they are disc brake too.
Post by TORX on Jan 18, 2010 18:24:25 GMT -8
It is a smidge narrower than the YJ dana 35 (I think 1" on each side). I'm pretty sure it's the same case for the XJ as well. I'm in the middle preparing to swap one into my YJ. If you get the '96 and later, they are disc brake too. For an XJ, I believe the difference is 5/8" per side. Hardly noticeable at all, and not a big deal. $200 is a great price too!
Post by fivendime on Jan 19, 2010 22:51:59 GMT -8
LOL I feel like a real dork right about now.....not to mention a newb. Me and Ryan were headed back to my house after the PNW meeting to drop me off when he said I think you have an 8.25 rear end and not a 35 as we pulled into my driveway.....I said to be honest I had just assumed it was the 35....umm nope...Its the flat bottom and not a round one. So it looks like I wont be needing this rear end as of now. I would buy it if I had spare cash but right now I dont since I just purchased my lift.
Sorry about that! Feel free to laugh at me....hahaha
redxj
Post by redxj on Jan 20, 2010 4:46:41 GMT -8
LOL I feel like a real dork right about now.....not to mention a newb. Me and Ryan were headed back to my house after the PNW meeting to drop me off when he said I think you have an 8.25 rear end and not a 35 as we pulled into my driveway.....I said to be honest I had just assumed it was the 35....umm nope...Its the flat bottom and not a round one. So it looks like I wont be needing this rear end as of now. I would buy it if I had spare cash but right now I dont since I just purchased my lift. Sorry about that! Feel free to laugh at me....hahaha the 8.8 would still be a stronger upgrade than the 8.25. Look closer at the difference between the d35 & 8.25!!! Not much
Post by fivendime on Jan 20, 2010 16:53:18 GMT -8
Actually there is quite a difference between the D35 and C8.25. the main one is that the axle tubes are thicker and bigger, The earlier model 27 spline ones were slightly better then the D35 but the later model mid 96 and up 8.25 were 29 spline axles. The housing, gears, tubes, and carrier are all better then the D35. I know the 8.8 will be a little stronger but a 29 spline 8.25 should handle at least 35's locked up with some good axles. I wont be going over 33's so Im good for now. I think lockers are about the same price over all, as well as axles so for me to spend the extra cash now just isnt worth it, though I would LOVE to have an 8.8 some day.
rizon
Post by rizon on Jan 28, 2010 11:12:34 GMT -8
So is this gone or still available?
Post by m38crawler on Jan 29, 2010 16:07:36 GMT -8
I'm interested if still around...
Post by bigstuck on Jan 31, 2010 21:39:41 GMT -8
Actually the m35 in the xjs and yjs are the same width. And the 8.8s stock out of the xplorers are about 1" narrower per side. Either add wheel spacers to bring back to same as your rear end ant 100 bucks sourced just about anywhere and from myself at woody's made from billet aluminum or get the super 88 kit from superior axle and gear. which makes it the same width as you need and eliminates the c clips at the same time with HD chromoly axles. Also in stock at the shop.
Post by 400sbk25 on Feb 3, 2010 23:06:46 GMT -8
sorry guys i dont have the email notification set up but its already gone.
if enough people are interested i could make another JY run ??
Post by czjeeper on Feb 3, 2010 23:52:01 GMT -8
Just a heads up. Call Rose Auto Wrecking in Portland. They've got a bunch starting at $125.
Post by 400sbk25 on Feb 22, 2010 20:45:52 GMT -8
My project has changed and i have one more axle to sell if anyone is interested
