Post by 4stgmby on Oct 27, 2014 10:42:35 GMT -8
Took the top off to replace the cowl seal and decided it's a good time to start the rear bumper and swing-away. she looks sexy topless
Post by ODJeepster on Oct 27, 2014 21:09:19 GMT -8
Yes she does
Post by ODJeepster on Oct 31, 2014 16:31:50 GMT -8
Look what I scored after work today Dana 44 front out of a Wagoneer....super excited!!! Now the decision, narrow the housing to Jeepster width or go Waggy width both ends....any suggestions?
Post by petee on Nov 2, 2014 19:58:29 GMT -8
I narrowed my front d44 to wide track cj width. In hind sight I would not do it again. In like 6 months I regretted it. Go waggy width now. is that a wide track?
Post by ODJeepster on Nov 2, 2014 20:41:54 GMT -8
Its out of a 74-79 Waggy, I've been in debate on cutting 5-1/4" out of the long side and running early Bronco inner axle. If I stay full width I will have to come up with a Waggy rear. It's a financial vs performance. Paul, what's your number one reason for thinking you would rather be full width?
Post by petee on Nov 3, 2014 10:40:46 GMT -8
Stability on hairy stuff on the trail You can narrow the track width with your final choice in rim backspace to your magic number what ever it may be. 61"/62" wheel mounting surface is very popular in the northwest. It usually puts your wheels outside to outside measurement around 78" plus or minus. also the more backspace you run on your rims the less stress is directed at parts like ball joints and bearings, also scrub radius is reduced provided your rear axle is a little narrower then you front.
Also. From my experience I would stick with stock length shafts wherever possible. I will say however I have already started down the opposite path and have custom length stuff everwhere. If I was to do it over I would run stock length everywhere. But that's much harder them custom. Good luck.. lots to think about. Keep the questions coming if you got them.
Post by petee on Nov 3, 2014 10:45:49 GMT -8
'93-UP ISUZU RODEO/HONDA PASSPORT DANA 44
Differential Location: Centered Lug Pattern: 6-on-5.5 Good For: At 58 inches wide it's a good swap for YJs, TJs, and XJs that came with a Dana 35 Pros: Many came with 4.30 and 4.56 gears, strong housings, disc brakes, works great on late model Wranglers when matched with '80-'91 Wagoneer Dana 44 front axle
Post by ODJeepster on Nov 6, 2014 17:55:35 GMT -8
Thanks for the info Paul Been slowly making progress on the rear bumper..finally happy with fitment.
Post by ODJeepster on Nov 6, 2014 18:09:21 GMT -8
Started building rear sliders using 3x2 .188 wall tubing. They will sit at a 60 degree angle to match the bumper ends and original rocker panel angle.
Post by ODJeepster on Nov 6, 2014 18:14:06 GMT -8
The transition to the left and right rear wheel openings
Post by petee on Nov 7, 2014 20:10:29 GMT -8
Nice
Post by ExCabSwap on Nov 7, 2014 22:40:59 GMT -8
Just wanted to say that you have an awesome shop.
It must be nice having all that space!
Post by ODJeepster on Nov 8, 2014 9:06:46 GMT -8
Just wanted to say that you have an awesome shop. It must be nice having all that space! It is very nice, I can only use it from 5am to 6:45am while we are not busy. Other than that I use my 1/2hr lunch break to fab my stuff. Wish I had this stuff at home lol
Post by ODJeepster on Nov 8, 2014 9:08:44 GMT -8
Here is the rear bumper/slider combo painted and installed
Post by ODJeepster on Nov 8, 2014 9:10:22 GMT -8
