Thanks! I had to take the intake plenum off though because I got excited and put the engine and transmission in before wiring any of it, so now I'm trying to tie up all the loose ends! No pictures tonight, because there's nothing to show, but I've got almost all the wiring done.
Then, when I was hooking up the clutch slave cylinder, it burst in my face... I guess it has to happen at least once to everyone... So I replaced that tonight...
Do you know what sensor I could wire up a switch inside the cab to get idle up? I'd use it for when I get the york hooked up so I can just switch it on, hop out and air up the tires etc... I was thinking maybe power steering, because I don't have A/C...
So everything's back together, I'm working on getting the vacuum hoses in the right order, but other than that, it cranks over fine. Seems to not be getting fuel... starts when we spray starting fluid, and there's fuel pressure at the cold start injector, so I assume there's fuel in the fuel rail...
Haha... well, I got in touch with 7m4x4dude and he reminded me of a ground I had missed, and now she's running!
Video of the beast!
I guess it's a little loud for my phone.
I'll get a better video up sometime this week, but for now this will have to suffice. It looks like I'm right on track to be able to drive it to the meeting Tuesday!
Just curious: does anyone know how many amps a York compressor clutch pulls? I'm trying to decide if I need to run the clutch on a relay or not.
Dang! Yeah, the power source will be fed straight from the battery, to a normally open relay, which will be switched closed with an accessory wire which I'll tap. I was thinking of using that way there's no WAY I could even have power to the 'power' switch on the dash unless the motor is running. It's a bit more expensive, but I'd rather pay $5 extra bucks for a relay than wish I hadn't forgotten to leave a switch on.
I ran my multimeter and tested for resistance of the electromagnetic clutch... only 4 Ohms resistance. 12v/4ohms=3amps. so there's nothing too crazy running through it. If I can, I'll use a few relays just in case, but my fuse panel will have 5 amp fuses as backup safety... Better days ahead... no more scuba tank!
Just wanted to post a quick video of where I'm at so far. I've got the vacuum lines mostly sorted... Right now, I'm trying to wire in an A/C idle up VSV so that I'll have a fast idle setting for the York...
Just removing it to clean and paint. Later (as in years from now haha) I plan on doing an ex cab swap and fab up a flat bed... I really like the short wheelbase, but I also like the look and roominess of the excab on standard cab frame.
Right now, I'm working on cleaning this up and getting keys made:
ExCabSwap: The wind there looks horrible... Still worth it haha
Feb 1, 2016 18:43:45 GMT -8
ExCabSwap: Finishing up the fuel tank... Hope to see you all Tuesday in my extended cab!
Feb 6, 2016 1:43:36 GMT -8
poorboy: Can somebody give me the official rules for the Cowbell please?
May 8, 2016 15:26:47 GMT -8
Wyldman: The Cowbell... If you are a club member and you're on one of our wheelin' trips. If you get stuck on an obstacle and have to be pulled out by your winch or someone elses winch/strap. You earn the Cowbell.
May 9, 2016 15:46:03 GMT -8
poorboy: Wyldman, I got to see the passing of the bell at the meeting and learned quite a bit about the tradition.
May 11, 2016 13:03:11 GMT -8
ljdude: Who has the cowbell?
Jul 20, 2016 23:45:14 GMT -8
petee: who has the cowbell
Aug 7, 2016 20:00:28 GMT -8
bigstuck: Did anyone find the cowbell?
Oct 5, 2016 7:55:34 GMT -8
ljdude: No Cowbell for you!!!
Oct 18, 2016 20:20:27 GMT -8
ljdude: Shout Shout Let it all out These are the things I can do without Come on I'm talking to you Come on
Oct 18, 2016 20:21:45 GMT -8
ExCabSwap: I'm talking to you!
Oct 19, 2016 21:44:37 GMT -8
wvopowered: Any one going wheeling this Saturday I was planning on going to Ladee but I may not have anyone to go with now.
Nov 15, 2016 18:57:24 GMT -8
ExCabSwap: December 10th Toys For Tots event at Brown's. I'll be there representing Northwest Trail Innovations. Free seat if anyone wants to go
Dec 3, 2016 0:33:35 GMT -8
Wyldman: Merry Christmas everyone!!! Remember.... Jesus is the Reason for the Season!!
Dec 22, 2016 17:17:55 GMT -8
wvopowered: Any one planning on going on a run over new years weekend
Dec 23, 2016 17:08:37 GMT -8
pistonschick: REMINDER! Club meeting is on the 3rd Tuesday this month - April 18th, 2017 (not April 11th) See you there...
Apr 6, 2017 7:47:38 GMT -8
ExCabSwap: I'm leaving Saturday morning for the beach cleanup. Extra seat available
Apr 27, 2017 6:16:27 GMT -8
dbbd1: When and where are your next meetings? Thanks.
Feb 8, 2023 9:15:35 GMT -8
