Post by fivendime on Jul 29, 2010 21:08:13 GMT -8
ALAS! Its on the road again I have 30+ miles on it already today, though it took me 4 hours to do that cause I had to let it cool down all the time. They make no noise, and they are very smooth riding. The rear locker works in the gravel! Not sure about the front since I haven't mounted my solenoid yet (I have no fittings). I dont know how hot the front and rear ends are supposed to be when done driving 10 miles or so but I can hold my hand on the pumpkin no problem.....the rear is quite a bit warmer though. Here is the final gear pattern for my front D30 Drive side which I got a good picture of. Coast side which I couldn't seem to get a good photo of. And a shot of it installed. That Freeking air line on the housing was a nightmare. Due to the bracketry of my lift and the tall gears I had to angle it and do some weird things. I have clearance and its air tight so it should work great. Praise the Lord!!!! On to the next project!
Post by fivendime on Jul 30, 2010 13:26:43 GMT -8
Current state of my XJ, hahaha it never ends
Post by bigstuck on Aug 1, 2010 21:12:29 GMT -8
if your replacing your manifold throw both of those away as they are GARBAGE!!
Get the ones with the flex bellows in them and youll not have the issue of cracked manifolds anymore.
92xj
Post by 92xj on Aug 2, 2010 22:30:40 GMT -8
buy a doug thorley header and dont look back by far the best header you can buy for these jeeps
Post by fivendime on Aug 3, 2010 8:11:12 GMT -8
HELP!
Turns out my wheels have to much negative offset pushing the tire inside instead of out. I need either A: Spacers or B: New Wheels
Anyone have any spacers? I need at least 1" worth.
I went with my stock header that I welded up for now till I can afford a nice one.
Post by fivendime on Aug 4, 2010 7:42:03 GMT -8
Ended up buying a set of wheel spacers from Woody's 4x4 and they worked great. Thanks for the good deal Tom The tires are now on, both rear end and front end fluids have been changed as well as an oil change last night till 12. Also got my rock light tabs welded on so I can rivet those on this morning before I head to Winchester Bay for Dune Fest!
Post by fivendime on Aug 4, 2010 11:29:55 GMT -8
Here are some updated shots of it right now! I need to do some major fender trimming, buy or make some fender flares, install my catalytic converter, and get a slip yolk eliminator kit and CV drive line and I should be done for a while!!!! MMMMM yeah ;D
Post by m38crawler on Aug 4, 2010 11:59:10 GMT -8
buy a doug thorley header and dont look back by far the best header you can buy for these jeeps Thats what i have on my jeep and it has been re-welded due to cracks...
Post by m38crawler on Aug 4, 2010 12:00:07 GMT -8
Oh yeah, lookin good Joey...
Post by fivendime on Aug 9, 2010 19:23:36 GMT -8
Beef its whats for (on the cherokee) dinner. Here is one side of my new JCR Stage 3 rock sliders. Man are these nice, they weigh 50 lbs each. No more weak sauce WP sliders. You can read the box...lol These go on soon!
Post by TORX on Aug 9, 2010 20:25:17 GMT -8
You forgot to add that it's now a trophy winning XJ.
Post by fivendime on Aug 11, 2010 19:27:07 GMT -8
Post by fivendime on Aug 11, 2010 19:30:11 GMT -8
Next on my list, and hopefully before I go wheeling again!
Post by iceman on Aug 12, 2010 21:14:36 GMT -8
Beautiful!! Nice job Joey. Maybe we can hire you to do Ryan's as well when the time comes. - Lyzz
Post by m38crawler on Aug 16, 2010 9:58:05 GMT -8
